So you're looking to build a new fuel system? STM has got you covered!
We are now
direct with FUELAB and can offer some great pricing! Anything you need please PM us or give us a call at the shop
585-730-4314. And, of course, they are all on our website:
STM - EVO VIII-IX-X FUEL SYSTEM COMPONENTS
Click the image for pricing and more info.
Fuelab not only makes top of the line fuel system components, but they also are the best looking! And with 6 colors to choose from, there is no doubt you'll find the perfect combination!
Prodigy Fuel Pump
Prodigy Fuel Pumps are the auto aftermarket's first and only speed controllable DC brushless driven fuel pump. With digital fuel delivery you get unheard of electro-mechanical efficiencies in a package half the size of competing pumps (3lb, 6.9 x 2.63") with 6 colors and 4 models to choose from rating up to 1800 HP! If you plan on making serious power, these are the pumps you should be looking at.
515 Series Fuel Pressure Regulators
FUELAB 515 Series Fuel Pressure Regulators are designed with performance and flexibility in mind. They accept port style and non-port style union fittings without interference. Available in 6 colors with -10AN or -6AN inlets, supporting fuel injected applications up to 90 PSI. Both the 515 Series Fuel Pressure Regulator have a -6AN return port located on the bottom.
818 Series In-Line Fuelab Filters (Short 3" Filter)
FUELAB In-Line Fuel Filters keep your engine running clean featuring male AN / 37° flared fitting end caps, so you can attach them directly to other fuel system components. All six colors are available in -6, -8 and -10AN with 10 micron paper filter elements. Excllent filtration and easy to install compact design.
828 Series In-Line Fuelab Filters (Long 5" Filter)
FUELAB In-Line Fuel Filters keep your engine running clean featuring male AN / 37° flared fitting end caps, so you can attach them directly to other fuel system components. All six colors are available in -6, -8 and -10AN with 10 micron paper filter elements. These long filters offer more filtration and longevity.
718 Series Replacement Filter Elements
All racers demand top engine performance, but what ensures that? Clean fuel! The celluose (paper) element is for gas and diesel only where you may use the stainless filters with E85. Available for the 5" and 3" filters. The finer the micron, the better the filtration.
For more info please visit
FUELAB Digital Fuel Delivery or give us a call.
With this new addition we will be able to keep A LOT more in stock and be able to meet your demands a little easier. We will also be re-designing our FPR kits to incorporate a -10 regulator so when its time to upgrade all you have to do is change the lines and fittings!
Give us a call all this week for KILLER Pricing!!
Thanks
-STM
585-730-4314
