New Aeromotive 340HP drop in Fuel Pump
Old Dec 17, 2010, 08:29 AM
Chris@nolimitmotors's Avatar
Chris@nolimitmotors is offline
Old Dec 17, 2010, 08:43 AM
wizzo 8's Avatar
How much and is it louder then the 255hp? Not that it matters but just curious
wizzo 8 is offline
Old Dec 17, 2010, 08:44 AM
binky's Avatar
Wow! Cool! Another, new drop-in fuel pump, look's good!
I like having options
Will this fit in a Buschur double pumper (Is it the same size physical size as a Walbro 255)? What's the price?
-Bink
binky is offline
Old Dec 17, 2010, 08:59 AM
Should be quieter then a Walbro.
Old Dec 17, 2010, 09:04 AM
-Bink
They offer a pump that should work no problem in the Buschur set up. Pumps are going to be $165 shipped.
Old Dec 17, 2010, 09:06 AM
David Buschur's Avatar
For reference............this pump flows less than a modded Walbro, which use to be available only if you told us you were running E85 with our double pumper. It has been standard for the last few months. Just adding this so someone doesn't order it to replace a modded Walbro as they will end up with less flow.
David Buschur is offline
JDMevoBOOST's Avatar
Ethanol safe?
JDMevoBOOST is offline
Old Dec 17, 2010, 09:12 AM
Thanks David for pointing that out. I did not know that. So the deatschwerks pump should flow less also then correct?
Old Dec 17, 2010, 09:20 AM
binky's Avatar
Good to know, Thanks David.
-Bink
binky is offline
Old Dec 17, 2010, 09:24 AM
Originally Posted by JDMevoBOOST
Ethanol safe?
Yes good to go.
Old Dec 17, 2010, 09:26 AM
wizzo 8's Avatar
Didnt know you could mod a walbro. Guess Ill have to check it out.
wizzo 8 is offline
Old Dec 17, 2010, 09:28 AM
Chris, I got the same sales flier for the Aeromotive yesterday. I checked the flow rates on it compared to the DW, the DW flows more than the Aeromotive. Our modded Walbro outflows the Aeromotive all over and the DW at higher pressures.
Old Dec 17, 2010, 09:45 AM
Yea i just looked at the deatschwerks flow chart. It is pretty close between the two. With 10-15 LPH.
Old Jan 6, 2011, 09:39 AM
Overlay
Old Feb 8, 2011, 10:06 AM
Got some in today, checking the order in now!!
Quick Reply: New Aeromotive 340HP drop in Fuel Pump
