Recently we decided to go through our turbo kits for the EVO VII-IX. We offer the most complete and proven turbo kit on the market. The number of records set and race cars campaigned goes on and on. Well we understand times are not the best right now and saving money wherever possible can go a long way. It is for this reason we have now lowered the price of all our EVO turbo kits! In addition pieces that were originally required with the kit are now options making our kit even more affordable for some.
If that isn't sweet enough...how about this!
If you have ever purchased a competitors kit and provide proof of such we will knock an additional $200 off!!!
For instance:
Previously our widely popular GT35R kit retailed at $
4689.95
With our new pricing if you opt for no intake pipe and can provide proof of competitor kit purchase the new price is:
$3999.95!! saving you almost $700 from previous retail price!
You can view new pricing on all of our EVO turbo kits here:
http://www.amsperformance.com/cart/M...omponents.html
For those that are a little unfamiliar with our kits here is a detailed description right off of our site:
The AMS EVO VII/VIII/IX Turbo Kits are the standard that all other kits are judged by, designed to meet the demanding needs of road race, drag race and street cars alike. Our highly efficient header and collector design promote quick spool and produce maximum power allowing us to take full advantage of the true ball bearing GT series Garrett turbochargers we offer. With this tried and true combination, we have successfully achieved unparalleled drivability, response, and horsepower.
Setting the bar even higher, our header now features one piece collector and head flanges. Both of these pieces are investment cast in durable 304 stainless steel. These new pieces are stronger, more consistent and have smoother transitions than traditional welded together assemblies. Another great benefit of casting is reduction in stress risers created during welding. These stress risers are where assemblies are the weakest and failures usually start. Because the cast pieces significantly reduce the amount of welding required, you end up with a straighter, stronger more resilient assembly.
The AMS Evolution Turbo Kits provide proven AND repeatable results! This is the exact same kit used on our record setting Time Attack car for four straight seasons. This is the highest quality kit on the market, period. It comes preassembled with detailed instructions so installation is a breeze.
Features
* 304 Stainless Steel TIG welded thick wall header with investment cast collector and head flange. This is the most resilient and reliable header on the market! Our Time Attack car with thousands of racing miles can't even crack it!
* Turbo support bracket maintains turbo kit reliability under any condition. No other competing kit offers this.
* Lifetime Limited Warranty On Header for the *Original Purchaser*
* True Garrett Dual Ball Bearing GT series turbo
* Hand ported turbine housing / wastegate feed
* Genuine Tial wastegate
* Industry first dual slip fit recirculated wastegate dump that prevents cracking due to heat and engine movement (optional)
* Key wastegate placement to alleviate boost creep.
* NORDLOCK one way locking washers prevent the O2 housing bolts from backing out under racing conditions.
* Stainless steel flex section in down pipe eliminates unwanted stress on the header
* Kit includes ALL necessary parts and hardware for installation
* Class 10.9 fasteners & 4 ply silicon couplers. We use the best hardware and silicone so that it goes together right the first time
* Proven AND Repeatable Results! No other kit on the market has more race proven results behind it. The same AMS product you purchase is the same product found on our race cars!
* Kit is pre-assembled for easy installation
Kit Includes
* 304 stainless steel thick wall tubular header with cast collector and head flange
* AMS spec Garrett GT series dual ball bearing turbo of your choice
* Genuine Tial 38mm wastegate
* Integrated turbo support bracket
* Stainless steel O2 housing w/ dual slip fit recirculated wastegate dump (optional)
* Stainless steel 3” downpipe with stainless steel flex section
* Stainless steel oil feed line
* -8 AN oil return line
* 4 ply silicon water lines
* Polished aluminum lower intercooler pipe
* 4 ply silicon intercooler couplers
* Top quality hardware package including nuts, bolts and clamps
* Polished aluminum intake pipe with K&N air filter (optional)
* Slim line fan
* Upper radiator hose heat sleeve
* Detailed installation guide
Specifications
* AMS GT30R Turbo Kit - 475-525 wheel horsepower
* TURBO SPECS:
* COMPRESSOR WHEEL: GT30R 55lbs/min
* Inducer: 57mm
* Exducer: 76mm
* TURBINE WHEEL: GT30R 84 trim
* TURBINE A/R: 0.63
* Spool 3200-3800 RPM
* Excellent Compromise Between Street/Strip
Applications
* Mitsubishi Evolution 7, 8, 9
* Fits all USDM, JDM and European Models
Please feel free to PM with any questions
Eric
