As the title states we will be selling these for 549.95 shipped anywhere in the continental U.S. for a limited time. Get yours while supplies lasts!!!
The AMS Mitsubishi Lancer Ralliart Cat-Back Exhaust System is the most unique exhaust system on the market. It was designed to be used with the same high flow cat, resonated test pipe, or test-pipe used on the Mitsubishi Evolution X. It can also be directly bolted on to the factory catalytic converter.
The AMS Ralliart Cat-Back Exhaust System has undergone countless hours of research and development and has been designed to make the most horse power as well as shed serious weight off your Ralliart. Our exhaust features mandrel bent piping for the best exhaust flow. This system does not have any restrictions like other popular exhaust systems that "neck down" and hurt performance. Like all other AMS exhaust products this Cat-Back is TIG welded with 100% 304 stainless components including the flanges and hangers. The system utilizes factory exhaust hangers and includes a high quality slash cut 4" tip muffler. By simply installing this exhaust system you can expect to see as much as 15+ Wheel Horsepower gains over stock without even re-tuning the ECU!
Features
3" throughout entire system. Does not "neck down" like other systems
100% Stainless Steel construction. No mild steel flanges or hangers
All flanged connections. No band clamps or slip fits to come loose
24 lb. weight savings (21 lbs. compared to stock at 45 lbs.)
6" Of Ground clearance, no lower than the factory cross member
Bolts up to the factory catalytic converter, AMS High-Flow Cat, AMS Resonated Test-Pipe or AMS Test-Pipe
Includes gaskets and hardware (2 bolts and 2 gaskets, re-use 2 stock front bolts)
Unrivaled fit and finish
Specifications
304 Stainless Steel
3 piping .049 wall thickness
Polished Muffler w/ 4 Cut Tip
3/8" Thick Stainless Steel flanges
21 lbs
Applications
2009+ Mitsubishi Lancer Ralliart
**Click Here To Order**
