Go Back   evolutionm.net > Market Place > Vendor Announcements
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 27, 2009, 03:08 PM   #1
Gold Sponsor
Personal Sales Rating: (1)
Andrew@AMS's Avatar
Drives: 1994 eagle talon
**Product Release**AMS Mitsubishi Lancer Evolution VII/VIII/IX Dry Sump System
The AMS EVO VII/VIII/IX Dry Sump System is designed to prevent oil starvation, lower oil temperatures and add oil capacity all while freeing up horsepower. The failing point of most traditional “wet sump” oiling systems is the risk of oil starvation due to oil slosh during racing conditions. Under the sustained g-forces of racing oil can be pushed to one side of the pan causing vital engine components to be starved of oil. The AMS Dry Sump System helps prevent this by providing constant oil pressure throughout the engine despite driving conditions. This not only aids in motor longevity but also frees up horse power by removing oil from the pan where it can create drag on the crankshaft.
The AMS Dry Sump System eliminates the oil in the pan by using a remotely mounted tank, increasing oil capacity and providing better cooling. The improved scavenging of the Moroso oil pump increases vacuum created in the oil pan allowing for better piston ring seal and provides a constant supply of oil under any condition. There is a reason why most high end sports cars now offer a dry sump oiling system from the factory. While a dry sump system may be more costly than traditional wet sump oil systems it simply performs better!
Features
* Remotely mounted oil tank for increased oil capacity
* No more oil slosh leading to the oil starvation or aeration
* Insures steady oil pressure under the harshest of racing conditions
* Maximizes horsepower by removing oil from the pan which prevents windage
* Adjustable oil pressure output
* Improves oil scavenging
* Increase pan vacuum leads to better piston ring sealing
* True three stage pump
* Improved oil and engine cooling due to the externally mounted tank
* Eliminates the chance of oil pump failure by removing the stock pump
* Allows for easy mounting of oil coolers and external filters
* Better overall weight distribution due to remote mounting of oil reservoir
Kit Includes
* Custom sheet metal oil pan and scraper
* Aluminum CNC bracket to mount the pump in the existing A/C location
* True three stage oil pump
* Custom CNC pump drive pulley/mandrel
* External oil filter
* All necessary installation hardware (oil lines sold separately)
* Detailed installation instructions
* Oil tank / reservoir
Specifications
* TIG welded 6061 aluminum constructed oil pan
* Moroso manufactured three stage oil sump designed specifically for AMS
* 6 quart oil capacity
* CNC 6061 aluminum drive pulley/mandrel and oil pump bracket
Applications
* Mitsubishi Evolution 7, 8, 9 Models
* Fits all USDM, JDM and European Models
Please Note:
* Not recommended for street use
* A/C must be removed for installation
* Since every installation of the oil tank will be custom this kit is sold without oil lines. AMS recommends the user fit the tank where he deems fit then measure for the proper lines and fittings.
* We offer all necessary fittings and lines separately on our website which can be found here.
Product Installation Instructions
* Available on our website
**Click Here To Order**
__________________
Andrew C.
-Asst. Sales Manager-
Andrew@AMSPerformance.com
AMSperformance.com
Tel. 847-709-0530
  • World's QUICKEST EVO 8 - 8.42 with a best trap of 171 MPH
  • World’s Most Powerful EVO – 1142 awhp
  • 2008 AMS Racing – 40 Victories in Road Racing and Hill Climb
Online
Old Sep 1, 2009, 05:43 PM   #2
Gold Sponsor
Andrew@AMS's Avatar
Just sold 2 kits!
__________________
Andrew C.
AMSperformance.com
Tel. 847-709-0530
Online
Old Sep 1, 2009, 05:46 PM   #3
Personal Sales Rating: (48)
2005 Mitsubishi Lancer Evolution
My Garage
zbomb's Avatar
Drives: GG Voltex 8 / 05 Duc 999S / 08 Ford F150 5.4 / Mazda 323 GTX
Looks beyond sweet...great pics on your site as well.
I unfortunately will not be picking one up until I win the lottery. But then, tops on my list.
__________________
572HP@34PSI C16
506HP@29PSI 93/Alky
BR2.3/BR HTA35R
Tuned By Matt Koestner @ DSG W/Autronic Management on a Dyno Dynamics
Dressed in Voltex
DSG....
Offline
Old Sep 1, 2009, 06:54 PM   #4
Personal Sales Rating: (13)
Balrok's Avatar
Drives: Evo IX Race Car
Sweet!
__________________
ROBISPEC/// Xtreme Boost Metallurgy
"make yourself faster before you make the car faster, else your car reacts faster then you, thus you spin and die"
robispec.com
xtremeboost.com
Offline
Old Sep 3, 2009, 06:23 PM   #5
Personal Sales Rating: (0)
TommiM's Avatar
Drives: 2005 Evo VIII
how much vacuum does that pump create in the pan out of curiousity?
Offline
Tags
ams, capacity, car, dry, evo, evolution, install, lancer, manual, mitsubishi, oil, pressure, pump, sump, system, vital
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
