Jul 30, 2009, 06:21 AM
Silver Sponsor
Personal Sales Rating: ( 6)
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
Custom Evo 9 Clutch master cyl. Conversion=No more breaking!
Are you guys experiencing broken clutch master cyl? Does your clutch pedal just go to the floor? This happened to us previously 2x and we weren't going to stick around for the 3rd. After seeing a few of these threads popping up we decided to do something different. We had a metal evo 9 clutch master cyl. fabricated to fit the evo x clutch pedal assembly. We will be offering these as a kit both Installed and or made for you. Big thanks goes out to Tom at NRG-Tech for the Fab work and Slonez for the inspiration!
By doing this we believe it will be impossible to break the clutch master cyl now and there will also be no need for any type of clutch master rings to prevent the stock plastic cyl. from snapping in half under hard driving.
Initial impressions so far:
Great stiff pedal feel.(we have an exedy twin hd)
Can also be adjusted to stock pedal height with the Helm Joint.
Now onto some pics:
Pricing:
-$650.00 w/ core
-$850.00 w/out core
Includes:
Conversion, Evo 9 Clutch Master Cyl.
( Oem Evo 9 Clutch lines are on global back order, you must order a AMS S.S Evo 9 Clutch Line!)
$650.00 W/ Core for "Do it yourself"
$750.00 w/ Core to have us Install
$850.00 w/out Core
Some other minor fabrication and trimming of the clutch master tunnel is needed to make this fit.
NOTE: Here are all the part numbers you will need when calling to order the parts yourself. This Does Not Include The Part Number For The Master Cyl!
Rubber Hose- MR594664
Steel Tube- 2348A038
Bolt- MB5552841
Washers- MF660053
We will have 3 ready to go with a core exchange next Wednesday, September 30th! Call for availability!
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Jul 30, 2009, 07:44 AM
Personal Sales Rating: ( 1)
2008 Mitsubishi Lancer Evolution
Drives: 08 Apex Silver GSR
Slightly higher pedal from stock.
This is great news...thank you!
One question though, are you saying the clutch pedal in your kit is even higher than the already too high stock clutch pedal?
__________________
OEM Front Brake Air Guides
AMS UICP / Hot Pipe
TWM Short Shifter, Console Bushings, A6 Leopard Shift Knob
Perrin 25mm Adj. Rear Sway Bar
Perrin Cat-Back Exhaust
Deka ETX20L AGM Battery
Ralliart Tail Lights
AEM Intake
T1R Shifter Boot
AMS High-Flow Cat
Cobb Stage 2 Map
Works Under Hood Shifter Bushings
Offline
Jul 30, 2009, 07:47 AM
Silver Sponsor
It doesn't "grab" any higher. The pedal Itself lays at rest slightly higher than stock as compared to the brake/gas pedal. You get used to it rather quick.
It's nice being able to bang gears without having your clutch pedal slam the floor. So far so good!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Jul 30, 2009, 07:52 AM
Personal Sales Rating: ( 3)
Drives: X RS
Glad you managed to do the conversion.
Offline
Jul 30, 2009, 07:56 AM
Silver Sponsor
Quote:
You inspired us to tackle this project. Even though your pictures were for the jdm version, they still helped!
Thank You much!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Jul 30, 2009, 07:58 AM
Drives: 08 Evo X
Guys, great work. When its time for a clutch, I will bring mine to you. Is there any way you could post some comparison pics to the stock assembly. Kind of a side by side view?
__________________
RR Evo X GSR (loaded)
Ultimate Racing Turbo Back Exhaust
ETS IC Pipes and Intake
Cobb AP
Perrin FMIC
CBRD Tuned 347 whp/337 wtq
Offline
Personal Sales Rating: ( 0)
Drives: 2008 WW Evo X, 2006 Civic Si
I would think this would be risking pedal or mechanical damage. Did you put in a higher bumper or something to prevent putting too much pressure on the pedal since it no longer contacts the floor?
Offline
Jul 30, 2009, 08:10 AM
Silver Sponsor
Quote:
Sure, I will snap a few pics for comparison!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Jul 30, 2009, 08:11 AM
Silver Sponsor
Quote:
You read that wrong. I was saying It's nice to bang gears without having the stock evo x clutch master snapping in half which results in no clutch pedal. The stock master breaks and your clutch drops to the floor.
This solution will never break a clutch master cyl.
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Jul 30, 2009, 09:18 AM
Drives: WW EvoX
Great solution to a big problem.
__________________
Performance Mods: Nisei UIP - Ecutek Tune by Dynoflash @ ICS Performance Dynojet - Forge WGA - Forge Unos MBC - SX HFC w/ WB bung - Tsudo N1 Extreme Exhaust
Interior Mods: Defi White Racer Gauge - AEM UEGO WideBand
Exterior Mods: 20% Tints all around - Faux CF wing inserts
Offline
Jul 30, 2009, 09:53 AM
Personal Sales Rating: ( 2)
Drives: 08 EVO X WW GSR SSS Aero Navi
What parts are needed? I want to do this. Other than the EVO 9 master cylinder assembly and a stainless line of course. Can I send you the pedal assembly to do it?
Offline
Jul 30, 2009, 12:42 PM
Silver Sponsor
Quote:
Evo 9 master cyl and evo 9 lines. That's all you will need.
The master cyl tunnel needs to be notched out a little bit in order to fit the new modified evo 9 master cyl clutch assembly through. The clutch pedal will also sit an inch higher than stock when laying at rest.
You can buy the parts and send me the assembly and we can have the fabrication done as you see above for $200. If you would like to go into more detail, feel free to call me, I am here to 5 p.m! Thanks!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Jul 30, 2009, 02:11 PM
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Good to see some solutions out there. I wonder if anyone is planning to make a direct replacement for the X clutch cylinder.
What a terrible design by Mitsu, cheap bastards!
Maybe there will be a TSB.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Jul 30, 2009, 02:43 PM
Drives: N20 HR Z
Congrats on the success! My nissan's master cylinder had to replaced 3 times, POS. I will definately be doing this mod on my evo in the near future
Offline
Jul 30, 2009, 03:24 PM
Silver Sponsor
Tilton makes a replacement but we wanted an oem clutch feel.
Quote:
thanks..i still can't get over the fact they made it plastic..ridiculous junk.
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Tags
built, clutch, conversion, customized, cylinder, evo, evo9, evom, guide, labor, lancer, master, masters, mitsubishi, needed  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
