Go Back   evolutionm.net > Market Place > Vendor Announcements
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 30, 2009, 03:34 PM   #16
Silver Sponsor
Personal Sales Rating: (6)
DG Motors's Avatar
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
Just brought the evo x back in for pedal adjustment. With the Helm Joint we use, we can adjust the pedal to stock height. Page 1 updated!
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Old Jul 30, 2009, 04:31 PM   #17
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
Quote:
FTMFW!!!
Very good to see.
So I assume you can use a AMS EVO IX/VIII clutchline, since the fitting at the slave cylinder should be the same?
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Old Jul 31, 2009, 06:47 AM   #18
Silver Sponsor
DG Motors's Avatar
Quote:
Originally Posted by Clipse3GT View Post
FTMFW!!!
Very good to see.
I believe so
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Old Jul 31, 2009, 07:04 AM   #19
Personal Sales Rating: (0)
murlo26's Avatar
Drives: 08 RR X GSR
Send a message via AIM to murlo26
So a few questions....
If I ordered this...what all would I need to do to my car to fit this? You said something about trimming? Not sure if you meant the Master Cylinder or what.
Also, how much work is there in installation. You don't have to drop the tranny or anything nuts do you, lol???
Thanks DG.
Oh, do we just call to order? I have a feeling mine Master Cyl isn't going to hold up to a ~30psi'ish stock turbo spike on E-85 in a few weeks...
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
SOON: I see Redness on the Horizon and it's not a sunrise:)
Offline
Old Jul 31, 2009, 07:07 AM   #20
Silver Sponsor
DG Motors's Avatar
Thanks DG.
Just call your local dealer, order an evo 9 master cyl with all the lines.
Trimming of the Clutch Master Cyl "tunnel" (firewall) entrance needs to be trimmed and notched out to make this fit.
No the tranny does not need to be dropped. Your whole clutch pedal assembly must come out and be send to us for modification. Turn around time will be 3-5 days depending on your location!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Old Jul 31, 2009, 07:15 AM   #21
murlo26's Avatar
Drives: 08 RR X GSR
K thanks, I will let you know when/if mine goes to pieces. Hopefully if it does this is in my budget, otherwise I might have to try and do the AMS ring with a clutch install if my master cylinder holds and my clutch goes for simple cost savings. This option looks like a better solution though for sure.
__________________
UR Testpipe
AMS UICP
Perrin 3-port
Cosworth MX1 Cams
Offline
Old Jul 31, 2009, 07:40 AM   #22
Silver Sponsor
DG Motors's Avatar
Sounds good..stay in touch!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Old Jul 31, 2009, 08:53 PM   #23
iriejigga's Avatar
Drives: Evo X gsr, 03 S2k, 07 GSX-R 600
Good Job DG, cost a little more than the ring thing, but a whole lot better fix, thanks.
Offline
Old Aug 1, 2009, 12:00 AM   #24
Personal Sales Rating: (3)
2008 Mitsubishi Lancer Evolution
My Garage
aftershock141's Avatar
Drives: OB Evo X, Boosted RSX
Send a message via AIM to aftershock141
Awesome. I will be doing this over the winter.
__________________
OB Evo X w/ SSS and Aero
300+ whp Base RSX Crew #1
Special Thanks to: Suja1 Motoring and Dave at Whipfactory
Offline
Old Aug 1, 2009, 06:51 AM   #25
boostin20's Avatar
Drives: OB Evo X GSR, 72 c-10
Nice DG! Is it fairly straightforward what I need to notch/trim for the IX master cyl to fit the pedal assemby?
Offline
Old Aug 3, 2009, 07:07 AM   #26
Silver Sponsor
DG Motors's Avatar
Quote:
Quote:
Thanks guys. We are trying!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Old Aug 3, 2009, 07:09 AM   #27
Silver Sponsor
DG Motors's Avatar
Quote:
Yes. A little hard to get in there but far from impossible. Once there is enough room, the clutch pedal assembly will slide and bolt right in. After that you have a few plugs to connect and then a few lines with some bleeding. It will take 1-1.5 hours tops for the whole installation.
Remember, we came up with this, just call for help when the time comes and we will walk you through it!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Old Aug 3, 2009, 09:47 AM   #28
DVDee's Avatar
Drives: WW EvoX
Are you guys experiencing broken clutch master cyl? Does your clutch pedal just go to the floor? This happened to us previously 2x and we weren't going to stick around for the 3rd. After seeing a few of these threads popping up we decided to do something different. We had a metal evo 9 clutch master cyl. fabricated to fit the evo x clutch pedal assembly. We will be offering these as a kit both Installed and or made for you. Big thanks goes out to Tom at NRG-Tech for the Fab work and Slonez for the inspiration!
By doing this we believe it will be impossible to break the clutch master cyl now and there will also be no need for any type of clutch master rings to prevent the stock plastic cyl. from snapping in half under hard driving.
Initial impressions so far:
Great stiff pedal feel.(we have an exedy twin hd)
Can also be adjusted to stock pedal height with the Helm Joint.
Now onto some pics:
Pricing:
-$300 Labor+Fabrication
-$200 Evo 9 Clutch Master/Lines/Fittings
Total: $500 for the conversion+installation.
Some other minor fabrication and trimming of the clutch master tunnel is needed to make this fit.
I just wanted to point out that on my car the pedals aren't perfectly aligned. It looks like the brake pedal is a little bit higher than the accelerator and the clutch is a little bit higher than the brake. So the side effect of raising the clutch pedal probably won't be noticed. This looks like a great solution. I will be going to DG to do this when the time comes.
__________________
Performance Mods: Nisei UIP - Ecutek Tune by Dynoflash @ ICS Performance Dynojet - Forge WGA - Forge Unos MBC - SX HFC w/ WB bung - Tsudo N1 Extreme Exhaust
Interior Mods: Defi White Racer Gauge - AEM UEGO WideBand
Exterior Mods: 20% Tints all around - Faux CF wing inserts
Offline
Old Aug 3, 2009, 09:53 AM   #29
Silver Sponsor
DG Motors's Avatar
Quote:
Yes, that was before we adjusted the clutch pedal with our joint. We can get the clutch pedal within an 8th of an inch to stock! I will take new pictures and post them up shortly!
Let me know when you are ready!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Old Aug 5, 2009, 08:41 AM   #30
DVDee's Avatar
Drives: WW EvoX
I just want to be clear on this. According to the first post DG motors can get the Evo 9 parts for $200 for us and then have them modified and installed for another $300.
__________________
Offline
Tags
built, clutch, conversion, customized, cylinder, evo, evo9, evom, guide, labor, lancer, master, masters, mitsubishi, needed
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
