CBRD BBK TURBO Available Now!!
#32
not to be a downer because i was totally looking forward to the official release of this but i thought the point was to make a contender against the green and have it be cheaper. 50 dollars cheaper and not making the numbers of the green? maybe im missing something...
#36
keep in mind, we think the green and red are both great turbos.... but, we never had much luck with our clients being able to get them...supply.. etc...
regardless.... this turbo has its purpose... if you read the long thread, you will see much of this covered already.....
the turbo is not inexpensive to make... a billet comp wheel, new cast turbines, maching housings.... etc etc.... not to mention... how long did we spend developing it? over a year?
cheers
cb
#41
you dont make sense..?? THIS IS BASED OFF OF THE EVO 9 TURBO HOUSING...
the NON lite version is a FULL version if that is what your asking.
there are only TWO versions. a LITE which is just a NEW CBRD compressor wheel.
the FULL is a NEW CBRD compressor wheel and turbine wheel.
if you send in your EVO 9 TURBO...
USED Turbo modding goes like this... send yours in, its disassembled, appropriate parts are examined and replaced... then machining takes place... you will get YOUR turbo back, not someone elses. If there is excessive wear or damage to the core, we will discuss alternatives before further work is completed.
CORE Upgrade Full Version is 1250.00 plus shipping. 5-7 days to ship from when your turbo is received.
CORE Upgrade BBK Lite is 695.00 plus shipping. 3 days to ship from when your turbo is received.
#43
I've pmed you about 2 weeks ago about your bbk turbo, I'd be appreciated if you can respond to my pm.
And just a reminder, can you tell us the flow rate of the Full version, it wasn't listed in your 1st post.
#44
that threads way way too long. i was in that thread near the very begining though but its got some 40 odd pages i havent read since then. a friend noted that the turbo was finally done and i should come take a look. either way since things are short staffed and everyone is busy, later on next week or whenever when you guys have some free time, you should make a compilation of the data in there and post up an offical data thread with your tests and fingings.
