Well, just to expand on what it looks like to me..
the RJ12 connector on the UTEC is not used on the Evo, at least typically it isn't unless you have a DTEC. Usually you take the regular 9 pin serial cable from he UTEC, plug it into the back of the Tuner/Tunerpro, then the 9 pin connector on the front of the Tuner/Tunerpro has a serial port you connect to your computer.
I was told that the RJ12 connector on the UTEC itself, is just a serial port, but they never said specifically if it was just a different "plug" for the same serial port that the 9 pin connector is wired to, or if its a different port.
But to clarify, all of the documentation on the Evo UTEC definitely shows the 9 pin serial cable connected to the back of the tuner.
