Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Turbo XS UTEC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 27, 2008, 02:27 PM   #1
Personal Sales Rating: (12)
evoPirate's Avatar
Drives: 2004 evo RS
Send a message via AIM to evoPirate
Good idea?
I am wanting to run E-85 this summer, but I also want to be able to switch maps back to pump gas just in case for some reason I'm running low and can't find an E-85 station and need to run from the pump. As well, same situation if I wanted to take a road trip. With UTECs going for so cheap, would this be a good way to have my regular Dynoflash'd ecu for pump and switch over to the UTEC for an E-85 map? I've spent a few hours searching the tuning forums, but I'm not finding the exact answers I need. I'm not looking to be constantly switching stuff around, I have a few more mods left, then the car will be left alone besides needing to occasionally run pump
Offline
Old Jan 27, 2008, 02:35 PM   #2
Personal Sales Rating: (0)
03RRVIII's Avatar
Drives: 03 RR VIII
Cobb Accesport, or a Laptop with Tactrix Cable solves your problem
Offline
Old Jan 27, 2008, 11:35 PM   #3
evoPirate's Avatar
Drives: 2004 evo RS
true, but can any of that be had for the dirt cheap prices UTECs go for now?
Offline
Old Jan 27, 2008, 11:37 PM   #4
Personal Sales Rating: (5)
Jameson_IXMR's Avatar
Drives: an evo duh?
The utec is loosing support unfortunately, well not lost but shrinking. But it is a very good unit, just getting a little outdated. It would allow you to switch maps easily, with a trigger input. If you install one, you might want to just use it soley as it has many benefits over the stock ecu, and will let you switch maps on the fly, (also a good meth/alky/water injection failsafe.
Offline
Old Jan 28, 2008, 11:29 AM   #5
evoPirate's Avatar
Drives: 2004 evo RS
exactly, i'm not looking for anything super advanced or fancy. i just want 2 good tuned maps that i can easily switch
Offline
Old Jan 29, 2008, 06:10 AM   #6
Personal Sales Rating: (24)
EvoTech's Avatar
Drives: 03 BBY
A utec will allow you to do exactly what you are looking for for. Turbo XS is getting out of the engine managment business, but that does not negate the fact that the UTEC is a very powerful unit that offers a lot of potential. Just the feature of switching maps without a laptop is a great thing. Be sure to buy one with all the goodies. The map switch, map sensor and a tuner. You will not regret it.
__________________
Most sports use one ball. Racing requires two!
Offline
Old Mar 5, 2008, 11:32 AM   #7
Personal Sales Rating: (9)
Drives: 1st RS in TX, 74 Alfa GTV, '67 Land Rover IIA 109 NADA
Send a message via AIM to chris mccarthy
Cobb vs UTEC
sorry if i'm being redundant in threads here, but i just want to get an idea of the UTEC system. if my car is at 300-350hp this system, albeit older, seems to fit my needs. if got other Turbo XC equipment and they are rock-solid. i want some impressions from those who use both systems, esp as i am to add a MBC...thanks
Offline
Old Mar 12, 2008, 10:54 AM   #8
Personal Sales Rating: (6)
With the UTEC, don't add a MBC. It's a waste of money. Get a MAP sensor and use the UTEC to tune boost. You get rid of boost spikes adn can adjsut boost levels on the fly by switching maps. Way better in my opinion. Plus you cna use the MAP as a load reference instead of the MAF making tuning much more reliable and a heck of a lot easier. GO UTEC in spite of the lack of updates for it. I use the UTEC Control Center (UCC) which someone created and it works like a charm. Excel is useful for analyzing data too.
Offline
Old Mar 14, 2008, 05:09 AM   #9
EvoTech's Avatar
Drives: 03 BBY
Quote:
Ditto. I have been using it for 4 years at HP levels from 290 to now 500 HP and it works great. Many people don't like the idea of running meth all the time. The beauty of the UTEC is that you can have a meth only map and put the meth on a switch and only run it when you want. Plus they are dirt cheap used. For $400 you should be able to pick up everything that you need. Many of my friends run ane AEM with the same 50 trim as me. None have made more power or having a better running car as a result. Some of the old limitations of the utec are gone with the advent of ECU- Flash. The combination of the 2 is kick A$$.
__________________
Offline
Tags
lowell787
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
