Jul 24, 2007, 07:33 AM
Personal Sales Rating: ( 8)
Drives: Evo8
Max MAF signal with alcohol?
I am trying to ballpark what my highest MAF reading will be when running alky.
Current setup:
Stock Turbo, stock inlet pipe, MAF ~ 1820 @ 7200 rpms and 21 psi.
Future setup:
HFS-5 alchy kit planning to run ~ 26 psi dropping to ?(I don't know how much I will be able to hold)
I would like to get a ball park idea of how much higher the MAF reading is going to be so that I can rescale my tuning tables now rather than keep rescaling as I slowly up the boost. Anyone have an idea or better yet comparable data?
Another question: Is there a way to control a +12 output like the auxilary solenoid but individually with each map rather than globally? I would like to turn on and off the alky kit by selecting a map on the UTEC.
Thanks
__________________
Mods: 3" TBE w/High Flow CAT, 264+ Comp Cams, Walbro 255 pump, 650cc Fuel Injectors, Perrin Fuel Rail, Aquamist HFS-5 kit, Megan Street Coilovers, Hard Intercooler Piping, GM BCS, Defi Boost, EGT, and Fuel Pressure Gauges, StopTech Stage 2 brake kit, 18" Volk GTUs Gunmetal
Offline
Jul 27, 2007, 05:12 PM
Drives: Evo8
guys .....several days and not even a guess....i guess the forum is really dead
__________________
Offline
Aug 1, 2007, 01:02 PM
Personal Sales Rating: ( 0)
Drives: Lightning Yellow Evo VIII
Sorry - there isn't much reason to look here anymore...
Using the UTEC logging, I have seen over 2100 on the MAF at 24+psi.
Here is a log of a 1-2-3 gear pull, uphill to force increased loading (I was checking knock).
Code:
EXT Load Knock Mod Mod Mod
RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF
psia Hz % deg duty deg % (OL) Hz
1982 -8.8 96 11 00 00 +32.5 3.6 ECU. +0.0 ECU. 99
2036 -8.3 121 14 00 00 +33.4 4.4 ECU. +0.0 ECU. 128
2062 -7.6 136 15 00 00 +32.4 5.5 ECU. +0.0 ECU. 143
2136 -6.6 150 16 00 00 +33.5 5.5 ECU. +0.0 ECU. 152
2197 -5.9 154 16 00 00 +31.4 6.2 ECU. +0.0 ECU. 153
2295 -5.2 165 17 00 00 +31.3 5.7 ECU. +0.0 ECU. 185
2454 -4.5 254 27 00 00 +26.5 9.9 ECU. +0.0 ECU. 248
2525 -3.6 272 30 00 00 +21.9 10.0 ECU. +0.0 ECU. 257
2710 -2.6 282 30 00 00 +23.1 10.7 ECU. +0.0 ECU. 276
2853 -1.7 280 25 00 00 +27.3 9.9 ECU. +0.0 ECU. 343
3063 -0.7 423 72 10 00 +20.6 12.6 ECU. +0.0 75.00 577
3245 +0.0 464 100 10 00 +20.6 16.0 ECU. +0.0 75.00 500
3468 +0.9 608 100 10 00 +18.6 19.7 ECU. +0.0 75.00 410
3787 +2.6 692 100 20 00 +15.5 22.9 ECU. +0.0 75.00 896
4095 +4.2 819 100 20 00 +12.6 28.2 ECU. +0.0 75.00 788
4426 +6.1 1061 100 30 00 +10.8 33.5 ECU. +0.0 75.00 1101
4859 +8.9 1416 100 40 00 +8.9 47.5 ECU. +0.0 75.00 1250
5367 +12.5 1792 100 60 00 +7.1 60.7 ECU. +1.0 75.00 1893
5931 +16.7 2016 100 70 00 +9.1 68.3 ECU. +2.0 75.00 2049
6447 +20.5 2040 100 80 00 +11.4 69.6 ECU. +3.0 75.00 2000
6973 +23.1 2092 100 80 00 +14.7 67.0 ECU. +4.0 75.00 2192
7423 +24.3 2155 100 80 00 +16.0 68.6 ECU. +4.0 75.00 2252
7062 +22.6 162 10 00 00 +38.7 13.2 ECU. +0.0 ECU. 307
6510 +15.3 132 6 00 00 +38.6 12.4 ECU. +0.0 ECU. 448
6006 +6.6 128 16 00 00 +38.4 9.3 ECU. +0.0 ECU. 322
5688 -0.3 1043 96 10 00 +23.3 28.0 ECU. +0.0 75.00 1020
5717 -3.1 1187 100 10 00 +14.4 38.7 ECU. +0.0 75.00 1282
5611 +0.9 1533 100 30 00 +9.8 49.8 ECU. +0.0 75.00 1760
5717 +8.2 1923 100 50 00 +8.3 61.1 ECU. +0.0 75.00 1798
5973 +15.3 1992 100 70 00 +9.1 66.9 ECU. +2.0 75.00 2083
6242 +20.0 1976 100 80 00 +9.1 72.3 ECU. +3.0 75.00 2118
6472 +23.6 2032 100 80 00 +11.3 67.7 ECU. +3.0 75.00 2232
6734 +25.0 2032 100 80 00 +12.5 72.1 ECU. +3.1 75.00 2016
6958 +24.8 2100 100 80 00 +14.6 70.9 ECU. +4.0 75.00 2173
7168 +24.5 2109 100 80 00 +14.6 69.7 ECU. +4.0 75.00 2272
7407 +24.0 2109 100 80 00 +16.0 68.4 ECU. +4.0 75.00 2232
7062 +22.6 398 10 00 00 +37.6 10.8 ECU. +0.0 75.00 188
6747 +16.5 114 8 00 00 +38.7 8.9 ECU. +0.0 ECU. 87
6313 +7.8 653 25 00 00 +37.4 19.6 ECU. +0.0 ECU. 896
5611 +2.6 1123 100 10 00 +15.2 34.9 ECU. +0.0 75.00 1131
5727 +0.4 1533 100 30 00 +10.0 48.7 ECU. +0.0 75.00 1506
5757 +5.2 1851 100 50 00 +9.1 62.3 ECU. +0.0 75.00 1953
5837 +13.9 1930 100 70 00 +8.4 64.8 ECU. +2.0 75.00 1923
5931 +19.8 1901 100 80 00 +8.3 66.0 ECU. +2.8 75.00 1968
6082 +23.6 1937 100 90 00 +8.8 70.0 ECU. +3.2 75.00 1953
6184 +25.5 1984 100 90 00 +10.3 68.4 ECU. +3.8 75.00 2173
6313 +25.9 1976 100 90 00 +12.4 72.1 ECU. +4.0 75.00 1968
6459 +25.9 2016 100 90 00 +11.8 68.9 ECU. +4.0 75.00 2136
6587 +25.7 2008 100 80 00 +13.0 68.9 ECU. +3.0 75.00 2155
6734 +25.2 2032 100 80 00 +12.9 70.0 ECU. +3.0 75.00 1984
6830 +25.0 2074 100 80 00 +14.2 67.7 ECU. +3.4 75.00 2155
6973 +24.8 2049 100 80 00 +15.7 68.1 ECU. +3.8 75.00 2100
7032 +24.5 2049 100 80 02 +13.1 72.7 ECU. +4.0 75.00 2232
7153 +24.5 2083 100 80 00 +13.2 67.1 ECU. +4.0 75.00 2252
7278 +24.5 2100 100 80 00 +13.8 71.0 ECU. +4.0 75.00 2260
7473 +20.5 292 8 00 00 +38.8 10.6 ECU. +0.0 ECU. 385
7062 +12.7 136 5 00 00 +38.6 10.4 ECU. +0.0 ECU. 123
6958 +3.5 90 0 00 00 +38.7 10.1 ECU. +0.0 ECU. 159
6915 -5.7 70 0 00 00 +28.9 9.0 ECU. +0.0 ECU. 71
6802 -11.4 75 0 00 00 +28.8 9.0 ECU. +0.0 ECU. 45
6693 -12.8 78 0 00 00 +28.7 9.0 ECU. +0.0 ECU. 102
6587 -13.0 64 0 00 00 +28.7 9.0 ECU. +0.0 ECU. 59
6472 -13.2 73 0 00 00 +28.6 9.0 ECU. +0.0 ECU. 75
__________________
Mike - Evo-NY Crew #083
TSE: The Tri-State Metropolitan Area Evo Club
See my mods HERE
Quote:
Originally Posted by Basalix
I am pretty non-partial. Punani is punani. As long as it doesn't look like someone drug an axe between her legs, I will generally bury my face in it.
Offline
Aug 1, 2007, 03:29 PM
Quote:
Hehe - and it will probably take a week for you to discover somebody answered...
__________________
See my mods HERE
Offline
Aug 1, 2007, 04:42 PM
Drives: Evo8
 Thanks man, but what turbo are you running? It looks like it spools way to slow to be a stocker.
__________________
Offline
Aug 2, 2007, 03:26 PM
You'd think it was bigger, but it's an Evogreen.
I was clinbing a fairly steep hill to place a great deal of "load" on the car for the logging.
__________________
See my mods HERE
Offline
Aug 6, 2007, 01:17 PM
Personal Sales Rating: ( 33)
Drives: 04 RS and 08 GSR
I agree that full boost is much much too late, even for an EvoGreen. The fact that you were going uphill is even worse -- that should make it spool faster relative to RPM (like being in a higher gear).
Offline
Aug 6, 2007, 05:37 PM
Yeah, I'm still fighting with minor boost leaks.
I'm getting ready to order replacement seals for my TB shaft. Thing hisses like a pissed snake at 6psi.
__________________
See my mods HERE
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
