May 26, 2007, 05:45 PM
Personal Sales Rating: ( 1)
Drives: 2003 BR35R Evolution Lancer/2003 SRT-4/2007 GSXR1000
Keep BLowing Engine fuse? Help
Keep blowing engine fuses? Is the utec the problem.....Is driving me crazy....I have searched high and ow looking for bad connection loose wire something cant find anything???
Started while back got real bad then stopped for months know seems to be back again....went to movies and it put me on th e side of the 4 times popping the fuse????
ANyone know or think they may know what is causing this is pain!
Offline
May 26, 2007, 05:48 PM
Personal Sales Rating: ( 7)
Drives: Buschur Powered IX
do you have a 02 fix? if so your 02 can be grounding out on the body
Offline
May 26, 2007, 05:50 PM
Drives: 03 evo VIII
Short somewhere, not familiar with the UTEC. Any mods recently put on? WHAT fuse is blowing? Are you in the band "Otown"?
__________________
03 EVO: AMS 2.3L Stroker/Stock EvoIX turbo/Invida O2/HKS 280 cams/Mellon tune/Walbro 255 /RMR turbo back/cat-delete/QTP cutout/custom sidepipe/ Tanabe Sustec Pro SS II. Coilovers/PWR radiator & Intercooler/AMS lower IC pipe/Exedy HD Twin metallic/ Cusco 23mm rear sway bar/Perrin endlinks/stainless lines/B&M short thro/AEM UEGO guage/HKS DLI II/Team Dynamics rims/Forge BOV/Fidanza Cam gears/Team RIPP transfer case / Cusco trunk brace/C-west Full CF-GT wing. (Adj.)
Offline
May 26, 2007, 05:51 PM
Will check the o2 again.....I have cel turned off by the utec so no light....but will check o2 again.........
Offline
May 26, 2007, 05:54 PM
No band from orlando........Just recently upgraded drivetrain to shep but nothing electrical added..
Sucks will be driving the bamb car dead and roll to a stop then..... the intercooler sprayer turns on constant spraying? When i never turned it on???
Offline
May 26, 2007, 05:57 PM
Drives: 03 evo VIII
OK, the IC sprayer could be: you spilled coffee, or soda in the console,and you bumped it, in the "on" position. Happened to me many times.
What fuse are you replacing?
__________________
Offline
May 26, 2007, 06:03 PM
engine fuse under the hood in the fuse box.....Did not turn IC sprayer on...Fuse pops car dies and sprayer starts spraying ........
Offline
May 26, 2007, 06:04 PM
put new fuse in car starts prayer turns off and off I go for couple more mile then POP all over again back on side of the road...
Offline
Drives: 03 evo VIII
What does the cover say the fuse is for? It says "ENGINE"? How many amp fuse? Or is it a relay "box"?
__________________
Offline
May 26, 2007, 06:07 PM
Quote:
I keep blowing the number 8 fuse in the fuse box under the hood.....All has on it is picture of the engine is a 20 amp fuse...
Offline
May 26, 2007, 06:32 PM
anyone know what the number 8 fuse exactly for?
Offline
May 26, 2007, 06:50 PM
Drives: 03 evo VIII
If you find that out, you know what is shorting out. Wherever that fuse goes to. I will try to look.
__________________
Offline
May 26, 2007, 06:52 PM
Drives: 03 evo VIII
Is this one in the photo the same fuse you are talking about?
Easy fix if this is your "fuse"
Blowing fuses
__________________
Offline
May 27, 2007, 08:04 AM
Blowing fuses
thats the fuse will check today see if o2 is touching car frame....
Offline
May 27, 2007, 07:01 PM
Update....got under car believe it was the o2 sensor on my test pipe hitting chasi....Used electrical tape and wrapped it.....took it for a spin no problems yet.........Hope that was it thanks for th advice...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
