Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Turbo XS UTEC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 11, 2007, 11:36 AM   #1
Personal Sales Rating: (1)
Drives: Evo 8
Not enough boost
Guys I'm new at this evo thing. Just got it a month ago. I just got a used utec. The problem I'm having is that after everything was installed the boost is only hitting 17 psi. I have a turbo back exhaust so I'm running the stage 2 map from turbo xs. The problem is that when I back that screw out on the boost controller thing it reaches 17 psi and stops. Even if I back it out more it only goes to 17 psi. I should be hitting 22. what is wrong.
Offline
Old May 13, 2007, 06:59 PM   #2
Personal Sales Rating: (8)
Drives: Evo8
First are you running open or closed loop boost? Also, have you messed with the boost map? What values are in the boost map?
__________________
Mods: 3" TBE w/High Flow CAT, 264+ Comp Cams, Walbro 255 pump, 650cc Fuel Injectors, Perrin Fuel Rail, Aquamist HFS-5 kit, Megan Street Coilovers, Hard Intercooler Piping, GM BCS, Defi Boost, EGT, and Fuel Pressure Gauges, StopTech Stage 2 brake kit, 18" Volk GTUs Gunmetal
Offline
Old May 14, 2007, 01:46 PM   #3
Personal Sales Rating: (9)
nirvevo's Avatar
If you are using that pathetic little UTEC ABC ball and spring boost bleed off valve that they supply, you can develope those kinds of issues.
I put a Hallman in place and the boost issues went away.
BTW:
Another issue when trying to use the closed loop feature is the Evo stock electronic boost control solenoid (ebcs). Most guys trying to run closed loop boost on the UTEC have replaced the stock ebcs with either the set up that MalibuJack describes (rigged GM part), or the Perrin model for an easy replacement.
__________________
"happiness is a warm 4g63"
"my dyno is a quarter-mile long"
And my absolute FAVORITE!
please shorten your signature there is no need for it to be 20+ lines long
thanks,
evom staff "
FINE...
03 VIII FP Red(80mm inlet & Oil Line)RMR3"TB&DPInvidia O2BuschurP&CStockExManiBuschurTwinPumpRC1200ccAeromotiveFuelRailNiseiICInjenIC&Intake
MilSpecTB&PIForgeBOVHallmanBCw/remote272KelfordsFPBeehiveSpringsExedyTwinTXSTuner Pro&WidebandE-85TobzTuned
Offline
Old May 14, 2007, 04:28 PM   #4
Personal Sales Rating: (3)
[EVO]Cookie's Avatar
Drives: ETS powered EVO VIII
Make sure you have the 1.7 filmware and check your boost duty cycle. If you have a 05 your giong to need a dyno and someone to tune it for you.
Offline
Old May 18, 2007, 03:55 PM   #5
Personal Sales Rating: (2)
dangerEVO's Avatar
Drives: 03 Mitsu Evo 8
Did you ever mess with your vac lines to your turbo. Make sure you still have that little ball in the vac line. couple years back I ran into the same problem when ever I increase the boost nothing happened later i found out that the ball was missing and went with an apexi avc-r for boost setting. Hope this help a little.
__________________
Danger,Danger
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
