Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Turbo XS UTEC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 30, 2007, 02:17 AM   #1
Personal Sales Rating: (3)
BoostN's Avatar
Drives: 530whp WRX sold to secret squirl
Perrin EBCS with Utec
Anyone running a ebcs with their utec for boost tuning? This is what I did on my subie and worked well. For the evo,
1. still hook up the WG to port 1 and turbo to 3, leaving port 2 open for the Evo?
2. I'm running a stock turbo so a good starting # would be for say 20psi?
Thanks, and I did try to search first, no luck.
__________________
Now I drive the IX!
Offline
Old Mar 30, 2007, 03:05 PM   #2
Personal Sales Rating: (5)
MalibuJack's Avatar
Drives: 03 Evolution VIII, 03 G35 6MT Coupe, 78 Malibu, 05 Dodge Durango
Send a message via AIM to MalibuJack Send a message via Yahoo to MalibuJack
You can configure it as a restrictor system or a bleed system.. I have the info but not here offhand. You can basically use the normally open port to run to the boost source, the common port to run to the Wastegate, thats the restrictor system and it works pretty well.
In a bleed system, you run the setup similar to the stock setup, boost source to a T, the T to the actuator, the other side of the T to the Solenoid's Normally closed port.
The first is a bit better for the stock turbo as it's faster responding, but can spike.
__________________
MitsuLogger V2.0 beta 1a - a Free MUT-II logger using the Tactrix Cable - Supported widebands: AEM, Zeitronix ZT-2, TurboXS UTEC and Tuner.. Download from http://www.aktivematrix.com
Offline
Old Apr 1, 2007, 07:07 PM   #3
BoostN's Avatar
At this point still using the avcr for boost as I'm still not sure to use port 2 or 3 for the boost sourse (normally open/closed?) Don't know which is what. But I do remember when having the instruction that I cant find online or in my garadge that port 2 is fast response and 3 is slow. My subie with a vf22 was better on slow. The evo with a 16g I would assume the same.?
Also, there are two turbotrix maps on the utec. Boost is set at 75 and so using open loop. I'm going to use closed loop for transitioning the boost to tps/rpm.
So I'll have to change all the #'s. If nobody knows a good starting # for say 20psi, I'll just do the trial and error and post when I find the winning #. LOL
Peace
Happy tuning all.
__________________
Now I drive the IX!
Offline
Old Apr 1, 2007, 07:37 PM   #4
Personal Sales Rating: (8)
Drives: Evo8
I am using a GM BCS (open loop) in a restrictor fashion as Jack mentioned earlier. I am happy with the way that it works. Basically, there is less than 1 psi of spike the way that i have it setup. My boost map goes from 62 at peak boost to 68 at redline, this keeps me at 22-23 psi constant. The 22-23 all depends on ambient temperature, which is why I run two seperate maps. One for cold days and one for hot days.
__________________
Mods: 3" TBE w/High Flow CAT, 264+ Comp Cams, Walbro 255 pump, 650cc Fuel Injectors, Perrin Fuel Rail, Aquamist HFS-5 kit, Megan Street Coilovers, Hard Intercooler Piping, GM BCS, Defi Boost, EGT, and Fuel Pressure Gauges, StopTech Stage 2 brake kit, 18" Volk GTUs Gunmetal
Offline
Old Apr 1, 2007, 09:28 PM   #5
Personal Sales Rating: (10)
Silvercar's Avatar
Drives: EVOLUTION 8 TRUE GSR 05
Send a message via Yahoo to Silvercar
Im usein it and i love it =) 26-25 PSI all day
__________________
Wicked White 05 LanEvo VIII GSR 402WHP/366TQ U-Tec tuned GT 3071R all supporting MODs on 91 OCT.
Offline
Old Apr 2, 2007, 03:08 AM   #6
BoostN's Avatar
thanks fellas. Appreciate your input.
__________________
Now I drive the IX!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
