Personal Sales Rating: ( 14)
Drives: 05 BLACK EVO Vlll
Utec log HELP!!!!!!!
i need help on the this i did a pull on 3rd gear and i got 2 knocks and after it hit around 5100rpm the car just sound like i got 10 backfire from the exhaust i let off after that i dunno whats wrong the my afr are 11:1 HELP!!!!!!
, , , ,Load,Knock, , , Mod, Mod, , Mod, WB
RPM, MAP, MAF,TPS,Site,Count, Ign#1, Inj#1, Ign, Fuel,Boost, MAF, AFR
, psig, Hz, % , , , deg , duty , deg, % ,(OL) , Hz,
2523, -5.1, 370,100, 10, 00, +15.3, 13.1,+14.3,+30.0,ECU. , 317, 00.00
2531, -5.1, 362,100, 10, 00, +16.3, 13.0,+14.3,+29.9,ECU. , 318, 00.00
2583, -4.3, 410,100, 10, 00, +16.4, 14.0,+14.3,+29.6,ECU. , 318, 00.00
2675, -3.6, 428,100, 10, 00, +15.4, 15.4,+14.1,+29.3,ECU. , 336, 00.00
2777, -3.0, 490,100, 10, 00, +15.4, 16.8,+13.9,+28.8,ECU. , 316, 00.00
2881, -2.4, 548,100, 10, 00, +13.6, 19.0,+13.4,+28.4,ECU. , 436, 00.00
3003, -1.4, 553,100, 10, 00, +12.9, 20.8,+12.8,+26.8,ECU. , 401, 00.00
3147, -0.4, 676,100, 10, 00, +11.4, 24.4,+12.7,+25.0,ECU. , 746, 00.00
3290, +0.8, 732,100, 10, 00, +9.3, 25.8,+12.6,+22.6,ECU. , 505, 00.00
3380, +2.3, 786,100, 10, 00, +4.2, 28.3,+12.5,+24.1,ECU. , 502, 00.00
3546, +3.9, 896,100, 20, 01, +3.2, 36.7, +7.4,+25.6,ECU. , 909, 00.00
3716, +5.9, 970,100, 20, 00, +3.3, 39.3, +6.9,+26.8,ECU. , 816, 00.00
3875, +7.8,1048,100, 30, 00, +2.5, 40.8, +5.1,+26.4,ECU. , 714, 00.00
4045, +9.0,1000,100, 30, 00, +2.7, 41.6, +4.7,+25.8,ECU. , 806, 00.00
4224,+10.2,1066,100, 40, 00, +2.9, 42.3, +7.6,+25.0,ECU. , 936, 00.00
4403,+10.8,1103,100, 40, 00, +3.9, 46.6, +7.7,+24.4,ECU. , 889, 00.00
4541,+11.3,1256,100, 50, 00, +3.9, 47.8, +7.1,+23.6,ECU. , 965, 00.00
4662,+11.5,1193,100, 50, 00, +3.9, 50.1, +7.4,+21.4,ECU. , 922, 00.00
4938,+11.0,1231,100, 50, 00, +5.3, 49.5, +9.0,+19.6,ECU. , 976, 00.00
5081,+10.6,1312,100, 60, 00, +6.1, 48.9,+10.8,+18.6,ECU. , 868, 00.00
5224,+10.0,1282,100, 60, 00, +6.2, 51.8,ECU. ,+18.0,ECU. ,1012, 00.00
5192, +9.6,1101,100, 60, 00, +7.5, 43.5,+11.0,+18.0,ECU. , 720, 00.00
5299, +8.8, 244, 8, 00, 01, +20.1, 9.5,ECU. ,+18.0, LCM., 53, 00.00
4938, +2.7, 107, 0, 00, 00, +36.3, 6.1,ECU. ,+20.2,ECU. , 52, 00.00
Reason: add
