Nov 26, 2006, 06:45 PM
Personal Sales Rating: ( 2)
Drives: Evolution VIII
Race Gas
i have a u-tec and i want to use race gas sooner or later. how does it work with the u-tec. so if someone could please explain it to me i would appreciate it.
__________________
"High power turbo, plus all wheel drive . It's not a car without them."
"If it cant race on gravel, snow, ice, tarmac, crazy uphill/downhill, all weather conditions....it's not on my list."
Offline
Nov 26, 2006, 08:04 PM
Personal Sales Rating: ( 22)
Drives: evo VIII
The Utec has the capability to store several different fuel/timing maps. If you already have a Utec, and have it tuned for pump gas, then an easy flick of a switch will bring up a different fuel/timing map that you can use for race gas. Obviously, you will need to write new fuel/timing maps to take advantage of the higher octane fuel, but once you have the maps, all you do is flip a switch when you want to change between pump/race gas.
Quote:
Online
Nov 26, 2006, 09:13 PM
Quote:
ok is it like the srt-4's with their high octane mode where it will kick them out if they dont have high enough octane for the amount of boost. does the utec have something like that. and say i use race gas and im done with high boost and i still have race gas in the tank can you flip over to a pump gas map and everything be fine?
__________________
Offline
Dec 4, 2006, 05:09 AM
Personal Sales Rating: ( 24)
Drives: 03 BBY
No It is not like that. It will not kick you over from one map to the next. You have to switch it.
__________________
Most sports use one ball. Racing requires two!
Offline
Dec 5, 2006, 06:59 AM
Personal Sales Rating: ( 0)
Drives: Lightning Yellow Evo VIII
In the case where you would be on your race gas map and have pump gas, the only thing in the UTEC that will provide some protection like that would be to set up the knock sensor fields to add fuel and/or take away timing in the event of the knock threshold exceeded. But remember that as soon as the knock count goes low again, the fuel/timing goes back to what it was, and then most likely the knock count will go back up again. So if you see your CEL blinking (knock warning) then it's time to check your map selection.
As for the other - race gas on the pump gas map, you should not have any troubles with that. You just won't be taking advantage of the race gas properties.
__________________
Mike - Evo-NY Crew #083
TSE: The Tri-State Metropolitan Area Evo Club
See my mods HERE
Quote:
Originally Posted by Basalix
I am pretty non-partial. Punani is punani. As long as it doesn't look like someone drug an axe between her legs, I will generally bury my face in it.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
