Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Turbo XS UTEC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 8, 2006, 06:39 PM   #1
Personal Sales Rating: (24)
EvoTech's Avatar
Drives: 03 BBY
Anyone USE UTEC to Trigger NX Express Solenoid?
I am plannning on using the UTEC to trigger my nitrous solenoid. Anyone do this? Any problems?
__________________
Most sports use one ball. Racing requires two!
Offline
Old Nov 8, 2006, 07:35 PM   #2
Personal Sales Rating: (22)
Drives: evo VIII
Quote:
my understanding is that you will need to use the Utec to power a relay, which in turn will power the solenoid on the NX system to be successful. The Utec itself (or at least the EVO version of the Utec peripherals) isn't designed to carry enough current to power the solenoid. Even then, powering up a relay is questionable. I have no first hand knowledge of this, only what I've read here in this forum.
Best of luck getting any information out of this forum of late. Seems it's been abandoned.
Offline
Old Nov 8, 2006, 07:38 PM   #3
EvoTech's Avatar
Drives: 03 BBY
It would not need to power the solenoid, just trigger it like microswitch mounted on the pedal would. Right?
__________________
Offline
Old Nov 8, 2006, 08:36 PM   #4
Drives: evo VIII
If wire correctly, yes. I'm trying to come up with an example, but struggling to explain correctly. It would be like wiring up your fuel pump to run at 14 volts all the time. Something like this cheap drawing I just made and the part needed.
relay needed, 20 or 30 amp should be fine, available at all auto parts stores.
Offline
Old Nov 8, 2006, 08:45 PM   #5
Drives: evo VIII
a little more explanation.... the Utec isn't designed to have high amps being passed through it's spare solenoid channel. 2 amps max! 2 amps will energize a relay, but won't energize the solenoid valves on the NX system, those probably require 10-20 amps. So, you use the Utec to power the relay, which in turn acts as the "switch" which allows battery voltage to reach the NX stuff. Hope that clears things up a bit.
Offline
Old Nov 9, 2006, 07:06 AM   #6
EvoTech's Avatar
Drives: 03 BBY
This seems to make sense, but I need to trigger 2 solenoids at the same time. One Fuel and one N20. Do you think that there will be enough juice from the spare solenoid outlet to split the signal and run 2 relays?
__________________
Offline
Old Nov 9, 2006, 08:40 AM   #7
Drives: evo VIII
You can power up both solenoids on one relay, so the load on the Utec stays the same. Just run your solenoids in parallel after the relay. Here's a better diagram than I can draw on the NX homesite.
http://www.nitrousexpress.com/Instructions/stage1.pdf
Offline
Old Nov 9, 2006, 12:07 PM   #8
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
The utec control of the solenoid is nice but there is still no way of launching off the spray so I opted for a different installation...
Offline
Old Nov 12, 2006, 07:11 AM   #9
EvoTech's Avatar
Drives: 03 BBY
Quote:
Why not. Couldn't you just set it to trigger the relay at 100 TPS. Oh wait that would only work with a 2 step which turbo xs has not given us!
__________________
Offline
Old Nov 12, 2006, 10:25 AM   #10
yup...
Offline
Old Nov 22, 2006, 09:59 PM   #11
EvoTech's Avatar
Drives: 03 BBY
Quick update. It works flawlessly. I like things simple and using the UTEC eliminates the need for a mechanical WOT switch and and RPM activated electronic switch. I love my UTEC, but damn, I need speed density!
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
