Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Turbo XS UTEC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 14, 2006, 12:37 PM   #1
Personal Sales Rating: (0)
dEdiYT11's Avatar
Drives: Black EVO 8
Send a message via AIM to dEdiYT11
High Fuel pressure due to UTEC??
So for some reason my fuel pressure is really high. When I am sitting there in neutral and rev up to like 4k my fuel pressure gauge says +6 BAR. I allready replaced the fuel pressure regulator and fuel pressure soleniod (both stock). All the lines seem to be in good shape (return) and there is no clog in the return line. The vacuum lines are all routed just like stock.
So could this possible be the UTEC?
I have a Walbro 255, Fuel Rail, 700cc injectors, and UTEC
Please help, this is not good getting 50 miles to half a tank of gas!
Chris
Offline
Old Oct 14, 2006, 02:36 PM   #2
dEdiYT11's Avatar
Drives: Black EVO 8
no one??
Offline
Old Oct 15, 2006, 11:05 AM   #3
Personal Sales Rating: (22)
Drives: evo VIII
it can't be the UTEC. That sounds more like what oil pressure should do, not fuel pressure. The Utec has no way of controlling fuel pressure, and a standard Walbro replacement pump won't cause that high of fuel pressure at idle, or rev'ing the engine.
Couple questions to help troubleshoot. Which Walbro did you get? Is it the standard that everyone else is using in the EVO? Base fuel pressure should be about 43#'s. At idle, it should be 43#'s minus whatever vacuum the manifold is under. So, if you disconnect the manifold vacuum line to the regulator with the car idling, fuel pressure should jump up about 7-8#'s (since your running 272's), and when you reconnect it, it should drop back down. Does the fuel pressure gauge respond that way? Does it still add fuel pressure on a one to one ratio with boost? For example, when boosting 20#'s, do you add 27-28 #'s more pressure than when at idle?
Is there any way you can be confusing fuel pressure with oil pressure?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
