Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Turbo XS UTEC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 5, 2006, 03:37 PM   #1
EvoM Moderator
Personal Sales Rating: (16)
Brian's Avatar
Drives: BUNDAY BLOODY BUNDAY
Possible transition issues?
So I'm finally getting around to looking into the transition issues I'm having with the utec. I've always had the same issues and it seems to have gotten worse since last year. Then again I only have 1K miles since then so it may just be in my head. Then again I have stopped using the stock BC to control boost and went with a MBC.
It seems that as the motor warms up these issues become smaller, but still exist. I only have issues under minimal load, as soon as I get > ~10% throttle the issues dissapear. Additionally AFR's skyrocket as soon as this happens.
Edit:
Compression: 180 psi across the board
Spark plugs: ngk bpr7es - .025 gap < 2 miles on new plugs.
log: http://www.beergoggles.org/EVO/UTEC/logs/10032006.txt
Video: Right click save as on both, streaming from the server isn't allowed.
http://www.beergoggles.org/EVO/media...s/MOV01461.MPG
Can hear what I'm talking about at 15 seconds in.
http://www.beergoggles.org/EVO/media...s/MOV01462.MPG
Can hear what i'm talking about immediately in the video & see it with the AFRs spiking to lean at 14 seconds in and then again at the end.
Offline
Old Oct 5, 2006, 08:39 PM   #2
EvoM Moderator
Brian's Avatar
video added, thanks to those that can help.
Offline
Old Oct 6, 2006, 12:24 PM   #3
Personal Sales Rating: (5)
BJai02's Avatar
Drives: 2001 Estoril Blue M Coupe & 2003 Weightless White EVO
Send a message via Yahoo to BJai02
I am sure it has to do with transition. Try to make your 10% load site to "ECU" for now and see if it helps.
One mor ething to check. If you have the logger, try to see if your fuel trim is in a reasonable range... +/-10
Offline
Old Oct 15, 2006, 12:55 PM   #4
EvoM Moderator
Brian's Avatar
Bjai02: thanks for your response.
So I bought evoscan and did some logging & have changed my injector scaling a bit on my 780's. I'm down to 590 right now. I also ecu'd out my timing map to get that out of the way. So now i'm back to where I used to be, if the car is warm it doesn't do it but once in a great while but while cold it's still an issue.
WOT is solid though, or was before I started dinking with the injectors.
Check out some of my evoscan logs:
http://www.beergoggles.org/EVO/ECU/e...5_13.09.08.csv
http://www.beergoggles.org/EVO/ECU/e...5_13.09.49.csv
http://www.beergoggles.org/EVO/ECU/e...5_13.10.45.csv
http://www.beergoggles.org/EVO/ECU/e...5_13.11.09.csv
http://www.beergoggles.org/EVO/ECU/e...5_13.11.52.csv
I tried to end each log just after my issue occurred, kind of unclear really on how to read the ST LT trims though.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
