Sep 20, 2005, 09:46 AM
Personal Sales Rating: ( 9)
TunerPro/EGT Question
I bit the bullet and bought the Pro to get EGT's in the log. I've read some guys think that EGT's are pointless but I kind of doubt that point of view. A pilot friend of mine said that they (at least used to) use AFR and EGT readings all the time.
But Here is my Question
I got the TurboXS EGT Type K Thermal Coupler which I am guessing is pretty standard. So I am wondering if I can't plug it in to an actual EGT guage when not using it to log temps in the Pro, I know that an adaptor would probably be necessary, as well as some calibration for the gauge.
Anybody have any knowledge or experience with this? (this is where I hope Jack gets interested and throws in his 2 cents :-)
But thanks for any help (from anyone)
__________________
"happiness is a warm 4g63"
"my dyno is a quarter-mile long"
And my absolute FAVORITE!
"please shorten your signature there is no need for it to be 20+ lines long
thanks,
evom staff "
FINE...
03 VIII FP Red(80mm inlet & Oil Line)RMR3"TB&DPInvidia O2BuschurP&CStockExManiBuschurTwinPumpRC1200ccAeromotiveFuelRailNiseiICInjenIC&Intake
MilSpecTB&PIForgeBOVHallmanBCw/remote272KelfordsFPBeehiveSpringsExedyTwinTXSTuner Pro&WidebandE-85TobzTuned
Offline
Sep 27, 2005, 02:49 AM
Personal Sales Rating: ( 4)
Drives: a drunken IX
bump. curious about it too.
Offline
Sep 27, 2005, 03:46 PM
Personal Sales Rating: ( 5)
Drives: 03 Evolution VIII, 03 G35 6MT Coupe, 78 Malibu, 05 Dodge Durango
Yeah, most type-k probes are the same, not sure if their calibrated the same, but they sure as hell looked identical to the Autometer probe.. So I don't see why you couldn't try it to see.. It won't hurt anything, just not read correctly.
Offline
Sep 27, 2005, 04:00 PM
Thanks Jack
I'll post my results.
__________________
thanks,
evom staff "
FINE...
Offline
Sep 27, 2005, 07:34 PM
So the tuner pro will create a 14th column in the UCC for EGT?
Offline
Sep 27, 2005, 09:22 PM
We wish.
Since I believe that the UCC display pulls it's info from the underlying Utec software, I think that the UCC is subject to the Utec's software limitations. (please correct me if I am wrong about that. It would be great news.)
Tuner Pro will show the EGT with the AFR in the "Tuner's" screen. The Pro will log AFR's and EGT's to it's own logger, but only the AFR's are piped over to the Utec's logs and show up on the far right side of the main logger.
I don't have mine yet so I'm only going from what I have read and been told by TurboXS
If you download the Pro's manual from TurboXS, you'll be able to see the different views that the Pro gives as well as how it works with the Utec.
__________________
thanks,
evom staff "
FINE...
Offline
Sep 28, 2005, 06:12 AM
Correct... The way to get around it is to log both through different serial ports.. I was thinking about rewriting my software to digest the two logs simultaneously..
Offline
Sep 28, 2005, 08:21 AM
Personal Sales Rating: ( 19)
Drives: 330i zhp
How can you log with different serial ports since you log UTEC stuff *through* tuner.
Unless you unplug utec from tuner and then log separately but then you won't see rpms, timing, tps etc etc so 2 logs would pretty much be useless.
We need the EGT column passed on to UTEC. I've been b1t<hing about this for a year now.
Offline
Sep 28, 2005, 10:19 AM
Drives: 330i zhp
Someone just answered my post by bumping the MPS logger thread lol
Offline
Sep 28, 2005, 11:48 AM
Jack , have you found a way to view both logs in a useful way, or do you switch back and forth between the dashboard views to view the read outs real time?
__________________
thanks,
evom staff "
FINE...
Offline
Sep 30, 2005, 08:58 AM
I have my TunerPro wired into a jump harness in addition to the passthrough.. This way when I log with the tuner pro I get the essential tuning data I need.. however I just basically use two serial ports and log at the same time both units (like the MPS software but I use my own tool)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
