P0234 Engine overboost code
Below i listed the code and freeze frame that i got off my OBD 2 scanner. When i get this code i hit what feels like a really fast fuel cut and im only boosting 10lbs of boost. ive looked for boost leaks and couldnt find any, i got a new wastegate and blow of valve and that didnt change anything either.. does anyone kno what is going on with my car be reviewing these specs? any info would be great thanks. rudy
P0234 Engine overboost Condition
DTC that caused freese frame P0234
Throttle position 52.9%
Engine rpm 4796
Load value 100%
Air flow rate 230.57 gr/sec
coolant temp 179
intake air temp 73
ignition timing 1%
Short term fuel trim 1
0%
Long term fuel rim 1
0%
Short term fuel trim 3
-100.6%
Long term fuel trim 3
-100.6%
Speed 49
Fuel system 1
open 1
fuel system 2
N/A
