Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Tech Guides
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 17, 2009, 05:47 PM   #1
Personal Sales Rating: (6)
Drives: Evo IX
Cam Belt tensioner tool any ideas for no tool?
Wondering if anyone has done anything to loosen the belt without using the tool possibly making somthing.
also can timing be off 180 degrees when the marks are lined up? im installing cams and i know on our tractors i work on the can be but this looks like it can NOT be 180 off TDC is TDC
__________________
Tuning Technologies Tune
Buschur TBE w/ high flow cat
Buschur uicp
Buschur mini battery
Walbro 255
HKS Race Suction intake
Buschur Race FMIC w/ LICP
Cosworth M2's
EPM Dump
Buschur short shifter and bushings
AEM Tru Boost 22psi
AEM UEGO, AEM Oil Temp in a Carbon HVAC Dash Peice
ACT 6 Puck Clutch and Streetlite Flywheel
Robi Springs and Rear Sway
APR Adjustable Wing
Custom Tow Hook
Offline
Old Mar 25, 2009, 10:12 PM   #2
ktk
Personal Sales Rating: (4)
ktk's Avatar
Drives: Evo VIII 2.3
It is possible to make your own belt loosening tool with some threaded stock and a nut, I have seen the specs on the forum before but for the life of me I can't find it with the useless search feature that we have on here. I tried and tried I want the info myself.
As for timing, your cams will spin once for every 2 rotations of the crank. So you are right, if the marks are lined up to the notch on the valvecover then you indeed have TDC.
You can also look pull off the valve cover and look at the cams. All the lobes should be pointing out, all valves closed for cylinder 1. Obviously if you have the oilpan off you can also look from under and see the piston up at the top of its travel.
__________________
Evokill 2:14 - The path of Evo is beset on all sides by the injustice of the speedtrap and the Plague of the Prius drivers. But blessed is he who in the name of disparity overwhelmeth the exotic in the valley of the s-bends. For he is truly his car's tuner, the finder of lost horsepower. And I shall strike down upon thee with great revs and furious acceleration those who attempt to obstruct or delay my overtaking and you will know my engine is turbocharged when I lay my powerband upon thee.
Offline
Old Oct 31, 2009, 09:38 PM   #3
Personal Sales Rating: (20)
panem's Avatar
Drives: evo 8
just order the tool from AMS. its fairly cheap
Offline
Tags
evolution, tensioner, tool
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
