Oct 18, 2008, 05:30 PM
Personal Sales Rating: ( 19)
Drives: '05 MR
Adjusting idle
I've been searching the service manual high and low and can not find any information on adjusting the idle. I found info on how to check it, but not a procedure for adjustment.
I did see:
"NOTE: The idle speed is controlled automatically by the idle
air control system."
Beforing adjusting the BISS, do you have to ground a plug or anything like with the DSMs?
Offline
Oct 19, 2008, 01:09 AM
Personal Sales Rating: ( 2)
Drives: evo ix
i think there is an SAS actuator that needs to be enabled (or disabled) with evoscan or the dealer's MUT tool.
Offline
Oct 19, 2008, 08:08 AM
Personal Sales Rating: ( 9)
Drives: EB Evo IX, RHD EG Hatch K20
The tatrix cable can be used by you or your local tuner to raise or low your idle through ECUflash along with many other things. Will not throw any codes.
Offline
Oct 19, 2008, 08:10 AM
Personal Sales Rating: ( 13)
Drives: 2006 Evolution IX, 2006 Range Rover Sport SC
I thought It had a screw by the throttle bodie than can be adjusted to a degree if that doesn't work check for boost leaks
Offline
Oct 19, 2008, 08:52 AM
Drives: '05 MR
Yes, there is the Base Idle Set Screw (BISS) on the t-body. Before you adjust the idle though, the IAC/ISC should be disconnected or disabled so it doesn't interfere with adjustment.
Offline
Oct 20, 2008, 01:52 PM
Personal Sales Rating: ( 0)
Drives: Mitisubishi Evolution
Can someone please post a pic where the base idle set screw is on the evolution. I have searched and I cannot find it. Please help me out
Offline
Oct 20, 2008, 02:17 PM
Drives: evo ix
on top of the tbody you cant miss it
Offline
Oct 20, 2008, 02:22 PM
I must be missing it casue I cannot find. Please can someone send me a pic. I have spent hours looks for this and am am stupid but I just need a pic and thats all. Please someone help me out. I will be forever greatful
Offline
Oct 20, 2008, 02:25 PM
Personal Sales Rating: ( 1)
Drives: 2002 Lancer OZ
There may be a rubber plug covering the screw hole.
Offline
Oct 20, 2008, 02:27 PM
ok so to the back of the throttle body there is a hole. Is the screw in there?
Offline
Oct 22, 2008, 09:13 AM
Personal Sales Rating: ( 54)
Roger - This is KC form gvr4.org. Man, I am having idle issues as well and messing with tuning...
From my searches, everyone says don't touch BISS, just mess with the rpm tables in Evoscan.
I may have a boost leak I guess, but last I checked, I didnt.
I do have a MIL.SPEC TB and wonder if my BISS does need adjusted...
Lastly, this SAS actuator to adjust BISS has been mentioned more than once. I need to know what thats all about
Offline
Oct 22, 2008, 09:15 AM
Quote:
yeah, its on the top of the TB and angled towards firewall. It has a philips screw in there you adjust with a screwdriver...
Offline
Oct 22, 2008, 09:21 AM
Roger - here you go!
Hope you have Evoscan 2.5 - This seems to be a popular way to set idle. I am about to try this tonight to see if my BISS is off...
EvoScan Actuator SAS Mode
Offline
Oct 22, 2008, 11:02 AM
Drives: '05 MR
Awesome, KC! Thanks.
I was having an idle issue and turned the screw. After a few moments it hit me like a ton of bricks... I forgot that you have to disable the ISC.
To make things even worse, my idle issue was cause from the PCV fresh air line that I forgot to reinstall after messing with the intake.
Offline
Oct 22, 2008, 11:07 AM
no problem, ole buddy. Let me know how it works. I have some serious idle issues plauging the car and me. Not sure if its the cam degree off, boost leak, bad 02 sensor up front etc etc...AAGH!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
