Aug 2, 2008, 04:29 PM
Personal Sales Rating: ( 7)
Drives: evo IX MR
repeatedly blown fuse?
twice now in the last 20 minutes the # 8 fuse in the drivers side engine compartment fuse box has blown while under moderate load. The picture associated with the fuse is the same as the check engine light symbol. what might be causing this?
Online
Aug 7, 2008, 02:02 AM
Personal Sales Rating: ( 2)
2003 Mitsubishi Lancer Evolution
Drives: 03 AS EVO
something seems to be shorting it out maybe a stripped wire grounding out check grounds also. i had a similar problem like yours and it was a stripped wire for me the one that goes to that fuse box also. also the ground for the fuse box was loose check those out.
__________________
grease monkey member #0
I WILL PAINT MY FACE WITH YOUR BLOOD
Offline
Aug 7, 2008, 06:35 AM
Personal Sales Rating: ( 4)
Drives: 04 WW SSL Evo/BlkonBlk single 2jz Lexus SC400
loose connection, exposed wiring, wires touching, ground out issue.. could be a few things really.. just have to go through process of elimination. Good luck man.
Offline
Aug 22, 2008, 12:08 PM
Personal Sales Rating: ( 18)
Drives: Sideways
Quote:
Sounds like I'm right up the street from you. Let's pick a day and chase it.
Scott
Offline
Aug 22, 2008, 12:17 PM
Drives: evo IX MR
Okay, it turned out to be the o2 sensor in the cat touching the bottom of the car any time I went over a decent sized bump. Got it fixed. Improperly hung exhaust mounts.
Online
Aug 26, 2008, 10:52 PM
Personal Sales Rating: ( 13)
Drives: cheetahs crazy with his Evo X MR
To the guys suggesting it's a short... It's not always. I fought a fuse blowing every time my AC / defrost turned on. I went through every wire in my car. Went through all the wiring diagrams. Spent 3 days chasing it down, turned out it was the fan control module. Sometimes it can be an actual electronic device that is causing the short / high amps and not a bare wire.
__________________
2008 Evo X MR GG -- New
2003 Evo VIII RR -- Sold
2004 Lancer Ralliart LB -- Sold
English Racing -- MidgetSpec -- ETS -- Ralli ////Art -- Blitz
Quote:
Originally Posted by EvosnatcH
Welcome to your new addiction, its kind of like crack with out all the side effects minus the burning hole in your wallet
Online
Sep 17, 2008, 02:11 PM
Personal Sales Rating: ( 1)
Drives: 03 lancer evolution 8
i keep blowing the same fuse everytime I turn the key to the on positon. It is fuse 8 in the engine bay. Anyone had luck fixing this. I do not believe that it is the o2 sensor.
__________________
3" tbe, GSC S1's, Aquamist hfs-1 100% meth, Greddy cam gears, Injen IC hard pipes & intake, ACT hdss clutch w/ Prolight flywheel, Walbro 255 lph, Greddy Profec B Spec 2 ebc, Fp Red 80mm, Syncronic BPV, ETS 3.5" IC
Offline
Sep 26, 2008, 12:58 AM
Personal Sales Rating: ( 0)
Drives: 05 ww viii
Quote:
The circuit from Fuse 8 goes into the MFI relay among other places. It's very possible that the MFI relay is shorting and causing the fuse to blow. The MFI relay is located in the relay center underneath the hood. Since most of the relays should be the same, just swap it with another one beside it to test. If if doesn't blow with a different relay installed, then you know that the MFI relay is faulty. Let me know how you make out with this. Thanks.
Offline
Sep 29, 2008, 09:38 PM
Drives: 05 ww viii
mt057, have you found the problem yet? It happens that jmcevo1 has the same fuse blowing in his car. Electrical Problem
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
