If the throttle plate is closed and your idle is high then that won't reduce your vacuum unless the IACV is wide open. Even then it should equalize.
-11 psi is actuially a lot of vacuum. There's a little confusion between a couple posters here and i think it stems from the fact that a standard autometer type boost meter shows vacuum in Inches Hg
20 inches of mercury = 9.8219556 pounds per square inch
11 pounds per square inch = 22.3987981 inches of mercury
If you are really pulling that then i would say you've got very healthy vacuum. It should actuially drop a little as the idle goes down.
however you said for sure it was -.70 hkPA... i don't know what the "h" is but if that's kilopascals then that's not much vacuum at all
(-.70) kilopascals = -0.101526416 pounds per square inch
