Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Tech Guides
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 15, 2006, 10:20 AM   #1
Personal Sales Rating: (2)
Drives: EVO MR
Engine blueprint specs
I am in need of blueprint specs for a 4G63. preferably the new engine but I will take what I get. Specifically, rod and piston weights, deck height, combustion chamber CC's, etc., etc. These are specs for a stock motor.
Offline
Old Dec 18, 2006, 10:28 AM   #2
Personal Sales Rating: (0)
rhds13's Avatar
Drives: siktype s13
hrrrmmm......this isnt a small block chevy the 4g63 you know, what are you trying to accomplish?
Offline
Old Dec 18, 2006, 05:15 PM   #3
Personal Sales Rating: (3)
TrinaBabe's Avatar
Send a message via MSN to TrinaBabe
Here are some specs for you for a stock engine:
Head Gasket: .005 Standard Value
Limit = .02mm
Grinding limit on gasket & head: .02 (Combined between gasket and head)
Cylinder Head Height: 131.9-132.1mm
Valves:
Face:
Standard - Intake - 1.00
Standard - Exhaust - 1.5
Limit:
Intake - 0.5mm
Exhaust - 1.0mm
Valve Length:
Standard - Intake - 109.50mm
Standard - Exhaust - 109.70mm
Limit:
Intake - 109.00mm
Exhaust - 109.20mm
Valve Springs:
Free Height - Standard - 50.40mm
Limit - 49.4mm
Squareness - Standard - 2 deg. or less
Limit - 4 deg.
Guides: Standard - Int - 0.02-0.05, Exhaust - 0.05-0.09mm
Limit - Int 0.10, Exhaust 0.15
Seats: Standard Intake - 49.29, Exhaust 48.40
Limit Intake 49.70, Exhaust 48.90
__________________
-Nunquam Desiderium-
-Timothy Russell
Offline
Old Dec 18, 2006, 05:20 PM   #4
TrinaBabe's Avatar
Intake Valve Hole Diameter:
0.3 Oversize: 35.30-35.33
0.6: 35.60-35.63
Exhaust Valve Seat Hole Diamter:
0.3 Oversize: 33.30-33.33
0.6 Oversize: 33.60-33.63
Valve Guide Hole Diameters:
0.05 Oversize: 12.05-12.07
0.25: 12.25-12.27
0.50: 12.50-12.52
Guides pressed fit until projection is: 19.5 Standard Value
Valve Guide Length:
Intake: 45.5
Exhaust: 50.5
__________________
-Timothy Russell
Offline
Old Dec 18, 2006, 05:31 PM   #5
TrinaBabe's Avatar
Oil Pump Gear Side Clearance:
Standard Values
Drive Gear: 0.08-0.14mm
Driven Gear: 0.06-0.12mm
Here is some stock crank info also:
Crankshaft Pin Outside Diameter ident marks:
I = 44.995-45mm
II = 44.985-44.995
III = 44.980-44.985mm
Piston Size Match to Bore Size:
Cylinder Bore Size Mark:
I = Piston Size "a"
II = Piston Size "No mark"
III = Piston Size "C"
Connecting Rod Big End Side Clearance:
Standard: 0.10-.025mm
Limit: 0.4mm
Piston Ring Side Clearance:
Standard for "No. 1": 0.03-0.07mm
"No 2": 0.02-0.06mm
Limit for "No 1" and "No. 2": 0.1mm
With the piston ring in the bore forced down with the piston, the end gap of the ring is:
Standard for No. 1: 0.20-0.30
No. 2: 0.35-0.50
Oil Ring: 0.10-0.40
Limit: No. 1 & 2: 0.8
Oil Ring: 1.0mm
Crankshaft Pin Oil Clearance:
(Plastiguage) Standard: 0.03-0.05mm
Limit: 0.1mm
__________________
-Timothy Russell
Offline
Old Dec 18, 2006, 05:40 PM   #6
TrinaBabe's Avatar
Crankshaft Journal OD (There is a table also to match to the correct cylinders, bearings, etc..):
Ident Mark: 0 = Size: 56.994-57.00
1: 56.988-56.994
2: 56.982-56.988
Bearing Cap Bolts:
Limit: 71.1mm
Crankshaft Endplay:
Standard Value: 0.05-0.25mm
Limit: 0.40mm (If past limit replace number 3 crank bearings)
Crankshaft Journal Oil Clearing (Plasti-Guage)
Standard: 0.02-0.04mm
Limit: 0.1mm
Cylinder Block Squareness/Warpage:
Standard: 0.05mm
Limit: 0.1mm
Grinding Limit: 0.2mm
Cylinder Block Height:
290mm
Bore Cylindricalness:
Inner Diameter: 85.0mm
Within: 0.01mm or less
Boring Finish Dimension = Piston OD + (Clearance betwwen piston OD and cylinder) - 0.02mm
Clearance between piston and chamber: 0.02-0.04mm
__________________
-Timothy Russell
Offline
Old Dec 18, 2006, 05:46 PM   #7
TrinaBabe's Avatar
Cylinder Bore: 85.0
Piston Stroke: 88.0
Compression: 8.8
Intake Valves Open (BTDC) 21 deg.
Closes (ABDC) 59 deg.
Exhaust Valves Open (BBDC) 58 deg.
Closes (ATDC) 18 deg.
Timing Belt stuff:
Tensioner rod length: 4.8-6.0
rod production length: 12
Rod pushed in (22-44lb): 1.0
Rocker Arms / Camshaft:
Camshaft cam height:
Intake 35.79-35.29
Exhaust 35.49-34.99
I think this should all be right. I can double check and look up the rest of it later but I dont even know if this is what you were looking for.
__________________
-Timothy Russell
Offline
Old Dec 20, 2006, 04:25 PM   #8
Drives: EVO MR
That's the stuff., TrinaBabe. Thanks. Any other bits are appreciated.
Offline
Old Dec 20, 2006, 04:38 PM   #9
TrinaBabe's Avatar
Ill see if I can post it up a better format or something
__________________
-Timothy Russell
Offline
Old Feb 12, 2007, 01:33 AM   #10
Personal Sales Rating: (1)
Drives: 06 EVO IX MR
Nice post on the specs. bump
__________________
2006 evo MR
Offline
Old Feb 13, 2007, 02:19 PM   #11
Location: City O Sin, MA...the not so sinish part though...
Drives: '05 TB Evo VIII
where the crap did you get all those? lol
__________________
Quote:
Originally Posted by feldguy
You're correct about the MBC and stock BC.
You're still an a$$hole and I dont like you.
Quote:
Originally Posted by 22stars View Post
...i'm not looking for respect here in the OT, that would be like looking for pussy in a gay bar...
Offline
Old Feb 16, 2007, 09:06 PM   #12
MrMejia's Avatar
Drives: The 1st Evo 8 in o'side
maybe he took the time and physically measured everything. Wow. . . thank you for the useful info.
Offline
Old Feb 21, 2007, 11:33 PM   #13
03_CT9A's Avatar
some good info
Offline
Old Aug 7, 2007, 12:22 PM   #14
Personal Sales Rating: (8)
Drives: goggles and a speedo
Quote:
Standard Values
I = 44.995-45mm
II = 44.985-44.995
I = Piston Size "a"
Limit: 0.4mm
"No 2": 0.02-0.06mm
No. 2: 0.35-0.50
Oil Ring: 0.10-0.40
Oil Ring: 1.0mm
Limit: 0.1mm
Does this mean it is impossible to just replace the bearings with high performance bearings if any OEM parts are still used (i.e., rod, crank) since each engine has different tolerences from manufacture?
For instance, if you catch bearing wear at first stages - copper just starting to expose on bearing surfaces - and the main and rod journals are still good, you can't just order a kit of high load journals as a replacement, you have to individually order each OEM bearing ID size for each cyl, and each main. Right?
Offline
Old Aug 23, 2007, 11:37 PM   #15
TempeRacerGuy's Avatar
Drives: 06 Evo IX MR
It's not the bearing ID, it's the thickness of the bearing itself to obtain a specified clearance.
If you are showing copper... find out what caused the wear, and insure that is resolved before completing the rebuild
"high performance bearings" are typically just a harder bearing that can withstand a bit more abuse... however these are of a standard thickness, and you cannot obtain as fine a clearance tolerance as with the stock bearings. So, there is a trade-off to using "high performance" bearings. Most builders stock 1 standard size of bearing, and ignore the fact that the clearances are slightly out of factory spec.
Just for a comparison:
Toyota uses 5 different bearing sizes for each the crankshaft journals, and 4 different sizes for the rods (as well as .5 os bearings). Meaning that there can be thousands of different combinations, and to have the right bearings on hand for a rebuild, you need to stock:
24 narrow Main journal bearings
6 wide journal bearings
20 rod bearings
I used to keep these on hand for the 3S-GE and the 4A-GE, and replinish my stock after each rebuild. at $3-$5 each, for each style engine I had about $200 worth of bearings in stock, just to have the right item on hand when I needed it.
__________________
Austin T
Dual Sub Box project completed. Thank you Matt and Wicked Car Audio Systems.
"The winner is not always the fastest, but always the one who slows down the least"
"races are won in the corners"
Offline
Tags
11, 12, 4age, bearing, bleuprint, blueprint, chevy, clearance, cylinder, engine, free, mark, piston, ring, rod, side, sizes, toyota
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
