Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Tech Guides
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 11, 2006, 12:52 AM   #1
Personal Sales Rating: (0)
goucho's Avatar
Drives: '06 Evo 9 MR
Question Thermodynamics Question
Ok, i know this may be a little off topic, but i figured that this section would be the smartest place to ask this question. Right now i'm taking a thermodynamics class in college (my last week before i graduate with a physics and mechanical engineering Bachlors Degree) and i'm learning a whole lot about engine cycles (otto, diesal, brayton etc....). Anyways, the teacher presented us with the following question.
"When i shower, i take off my glasses and leave them on the sink. When i get out, their not fogged up. Although sometimes when i put them back on they fog up. Why would this happen?"
I know it has something to do with psychrometrics, but i'm not really sure why. I figured someone here might have an idea.... Sorry if this is to over the top for the people here.
Offline
Old May 11, 2006, 08:17 AM   #2
Personal Sales Rating: (2)
Drives: 2005 EVO VIII
Why do you think it has something to do with psychometrics? Do you think he is trying to give you a trick question....like one on an IQ test?
If so, there can be a lot of different answers, like where is the sink, etc?
But, just think about it. What is the fog on the glasses? It's condensation, right? How does that happen and why? That happens because as air temperature rises, the water vapor saturation limit increases, so the air can hold more water. But, if the air touches something cooler, then the air at that interface with the object cannot hold more water anymore and the air has to reject that water vapor, which condenses it on the cooler object.
I can think of a few different answer to your question, but I'm not in your class, I have no clue exactly what your teacher is looking for, etc. But, you either need the glasses getting cooler or the air getting warmer, both already in an environment where the air satuaration limit is already reached.
Maybe you took a cold shower and your warm breath or body heat is causing a localized are of higher saturation that condenses on the cold glasses. There are numerous answers to the question.
Eric
Offline
Old May 11, 2006, 12:36 PM   #3
goucho's Avatar
See that's kinda along the lines that I was thinking, with the water vapor. Since the temperature of the water is most likely above 100 degrees and it's at atmospheric pressure, it's going to be saturated. Thus, condensation. Which is why the mirror would fog up. But then why would his glasses not fog up, until he put them on his face. I was thinking maybe because he has them on his sink, where it will be less likely to feel the temperature difference. That is until he puts them on his face where the sudden contact with his raised body heat causes it to fog them up. I mean, there are probably a hundred explanations for this, but I was just kinda curious what some other people might be thinking. It's nice to have other knowledgable people to talk to! Thanks for replying!
Also, i was thinking about psychrometrics because it has to do with dew points, vapor pressures and specific humiditys.....
Offline
Old May 11, 2006, 12:47 PM   #4
zmeli's Avatar
Drives: RS
CONDENSATION is a warming process
EVAPORATION is a cooling process
The relative Humidity in the bathroom after the shower very high so the dew point is low. Maybe the evaporation of water from your body is collecting on the glasses?
Offline
Old May 11, 2006, 01:34 PM   #5
Personal Sales Rating: (23)
Drives: 450ZX, Slow Tundra, LS430
Send a message via AIM to SuperHatch
Both faces of the glass in the eyeglasses are exposed to the steamed air.
Only one face of the mirror is exposed. The temperature differential on the mirror (one side is attached to a cold wall/medicine cabinet) accelerates the condensation.
As far as why it condenses when you put them on? I'm not sure to be honest with you. My best guess would be that the humidity level in the bathroom is high due to the shower, yet that air temperature is still relatively low (~80F). The body temp would beupwards of ~100F, the temperature differential across the glasses with the high humidity would cause the condensation....
__________________
I DO NOT ACCEPT PMs
"My life is a cup of sugar I borrowed before time began and forgot to return."
"For the message of the cross is foolishness to those who are perishing, but to us who are being saved it is the power of God."
I DO NOT ACCEPT PMs
Offline
Old May 11, 2006, 02:33 PM   #6
byron3636's Avatar
Drives: 03 evo viii
The glasses are warmer(less than body temp, but more than room temp) than the mirror(room temp) when you put them down therefore the water vapor will condense on the mirror faster....
as you put them back on your head, your body temp like superhatch said is much much higher than that of the steamy air. The temperature gradient from your the water on your body to that in the air is much bigger causing them to fog right away.
I don't think breath has anything to do with it at all.
Another thing to consider is the properties of the water. water vapor tends to condense faster on things that are "dirty/dusty". the water molecules cling to these other substanes more than pure clean glass... the glass are most likely much cleaner than the mirror.
Offline
Old May 11, 2006, 02:53 PM   #7
thechoc's Avatar
I think he's sofa king with you. One of my T.A.'s asked that same question but gave us a little more to work with when he presented it (aka volume of the room, air temp, water temp, etc). The answer ended up being the sink is lower than his head.
I wanted to stab him after that.
Offline
Old May 11, 2006, 03:24 PM   #8
Personal Sales Rating: (12)
Eric
if you took a warm shower and your body is warmer when you put on the relatively colder classes they will fog. but i'm guessing you said cold shower cuz then the glasses wouldn't get warmed up while they were waiting for you...
Offline
Old May 11, 2006, 03:27 PM   #9
i would stab him for that
Offline
Old May 13, 2006, 10:40 PM   #10
Personal Sales Rating: (4)
andenbre's Avatar
Drives: GG IX MR
I wrote the following before reading all the posts
how about this, the air at the sink level is cooler than the warmer water saturated air 3 feet higher. while you were in the shower the glasses stayed in this cooler air when you get out you dont even have to put them on your face to fog them up just hold them at arms length and eye level and water will condense on them. next time you take a hot shower after you get out of the tub stand there for a few seconds and take note of the temp at face level then sit on the floor, this will put your face at approx counter level and feel how much cooler the air feels on your face.... and the foor on your azz
__________________
06 mr, buschur tbe, buschur intake, o2 housing, lc-1, JDM M.A.P. sensor, self tuned ecu flash.
Offline
Old May 17, 2006, 06:52 PM   #11
Andrew LB's Avatar
Drives: 2006 Evolution IX
Send a message via AIM to Andrew LB
I was going to give this exact answer to the question. I have a mirror in my bathroom that is the full length of the wall. When i take a shower, the steam can only go up and over the top of the glass shower doors and stays high for obvious reasons. When i get out, i look at the mirror which has condensation on the top 2/3 of it. The bottom is clear.
__________________
2007 Sprint Blue A4 2.0T
sprint blue | 6-speed | convenience | premium | bluetooth | bose | sirius | nav | bi-xenon | rs4 rear sway | quattro
neuspeed exhaust | neuspeed springs | oettinger chip 91-93-100 | spp yellow fogs
Offline
Old May 18, 2006, 01:52 AM   #12
Personal Sales Rating: (5)
Adamk24's Avatar
Drives: Blue 07 335i
Steam rises. When the glasses are down low in the sink they are in the cold air. When you put them on your head, your in the steam. seems pretty simple to me....
__________________
'07 Blue 335i Coupe Stock... for now
'01 Black S2000 AP2 Converstion (Sold)
'05 White GSR 317/312 whp/tq (Sold)
'95 Black Eclipse GSX 231/235 whp/tq (Sold)
'94 Civic Ex Coupe w/ B16 swap Slow but Fun (Sold)
Quote:
Originally Posted by Marteinn View Post
btw dont want wheels, like mine tomuch, no rubbing at any,,, i´m soo drift crazy guy ;p
Offline
Old May 19, 2006, 03:35 PM   #13
thechoc's Avatar
Quote:
Nothing is that simple when you're an engineer, everything has to be broken down to the point of stupidity. I think it's an OCD thing that we pick up while in college.
Offline
Old May 21, 2006, 10:28 PM   #14
Personal Sales Rating: (1)
FastEvoFL's Avatar
Drives: a heep of trouble into an island of nothing...
Tell me about it. I always ask too many questions and it really screws up everything!
I wonder if this would work when using a psychometric chart assuming clsoe to 100% humidty? Couldnt you find dewpoints... wet bulb and dry build temps and figure out some actual answer to this all?
__________________
Emanage(Ign,Inj,MAP). HKS EVC-V. HKS Back. HiFlowCat.Megan DP. HKS RS Intake. MR Bov. Exedy Twin
Offline
Old Jun 20, 2006, 10:56 PM   #15
Personal Sales Rating: (8)
Drives: goggles and a speedo
Quote:
Originally Posted by goucho
"When i shower, i take off my glasses and leave them on the sink. When i get out, their not fogged up. Although sometimes when i put them back on they fog up. Why would this happen?"[.
Sounds like your Prof is weeding out the kids that still don't get it even at the end of thier senior year. Even with a 4.0 GPA some graduates still can't apply squat for working knowledge - even in the simplest form. JK
Ever wish the mirror in the shower would just stay unfogged for 1 minute so you can shave, brush, or whatever? You turn the water cold and still it fogs from your breath - what do you do? (Ans) Heat the mirror up with hot water first and it will be good for most of the shower depending upon it's size of thermal conductivity.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
