Stock 1/4 mile
Stock 1/4 mile
how are you guys breaking 100mph in the 1/4 all i can muster is 14.09@95.4mph 1.9 60ft. and that as good as it gets for me i just must have a weak evo from factory
do u have a boost gauge?
if not, get one so u can monitor how much you're boosting.
i am getting one soon, i think mine is also on the lower spectrum of the HP for factory evos
i'll find out as soon as i get my boost gauge installed
you saw evo's with 2.2 and still turned a 101, that was stock, I doubt that. The few times i ran I turned a 99.5-100.5 which is 13.5-7. It has alot to do with weather and driver
i ran 13.409@ 102mph at maple grove...100% stock...spare tire removed.... did a 13.46@98mph (figure that one out) at beaver springs.... i think the 98mph trap was due to me shifting at 7700rpm instead of at the redline...
Bone stock I pulled a 14.1xx at 96.xx (don't have slip in front of me) with a 1.90 60' time. I think it has a lot to do with location and how well you stock clutch grabs. Launching the same way I launch my highly moded GVR-4 I just burn the crap out of the stock clutch.... launching less agressively I bog the **** out of it. The bad launch doesn't explain the crappy mph though. I wonder what the elevation is in Milan Michigan?
Later,
Keith
Later,
Keith
wow so bone stock means bone stock right(0 mods or changes to the car) because i talked to a guy and he said he was bone stock and all he had was grounding kit, hks filter, and removed the pill. I think he ran a best of around 13.8 at 97 or so. but thats not stock either, although he said it was.
my first stock 1/4 mile in my car was crap(due to the driver), I ran a 14.5@95 with a 2.1 60ft 2nd gear grind and missed 3rd. I was very sad that day. I knew it as me thou, beause my trap was so high for a crappy launch and missing a shift.
did you use your push button water spray?? also the launch can make your times vary from 14.0 to 13.0
i did a
13.3 1/4
8.4 1/8
1.8 60 foot
my first time.
i did a
13.3 1/4
8.4 1/8
1.8 60 foot
my first time.
Joe's Evo X
Oct 9, 2014 10:33 PM
RyanB@VelocitySource
Nov 19, 2007 03:06 PM
