St. Louis, MO: Vishnu Dyno Days-->April 29 & 30
VISHNU PERFORMANCE SYSTEMS DYNO & TUNING DAY APRIL 28th & 30th
***POSTPONED UNTIL MAY 6th & 7th***
To be held at Axis Power Racing, Collinsville, IL
Axis Power Racing is hosting the event on their Dyno Dynamics Chassis Dynomometer, the same type used by Vishnu in their Blackhawk, CA facility. Ron at Axis Power has recently relocated his dyno to a new facility in Collinsville, IL.
Gateway Motor Sports
929 McDonough Lake Road
Collinsville, IL 62234
Map of location can be found here http://tinyurl.com/d246u
NEW CUSTOMERS
For Evolution 8: XFlash is $395.00 and XFlash+Custom Tune is $495.00
Xedes are $749.00. An Xede with custom map is $849.00 and $949.00 for two maps.
Xede w/ SMART upgrade is $995.00 and each custom map is $100.00. XedeFlash is $100.00--this raises the rev and boost limits of the stock ECU to work better with the Xede.
For Evolution 9: XFlash + Custom Tune is $750.00
RETURNING CUSTOMERS
For Evolution 8: Custom map for the Xede is $275.00 and $325.00 for two maps.
Custom tune for XFlash is $300.00
For Evolution 9: Custom tune for XFlash is $200.00
www.vishnutuning.com/dyno_day_saintlouis.htm <----Click this link to sign up and pay for your tuning services from Vishnu!! BE SURE YOU PUT YOUR SCREEN NAME AND REAL NAME IN THE SIGN-UP INFORMATION!!!
In addition, there will be a fee for $95.00 payable to Axis Power Racing for the dyno time. <--will verify in the next few days that this fee will be held over!
Axis Power will have 100 octane unleaded and C16 leaded race fuels on hand for race fuel maps. Price will be Axis' pump price-day of event.
Gateway Motor Sports 618-345-4464 will be able to provide mechanical installations and will have some parts on hand if you find you are wanting/needing something day of event.
Attendees that have paid and will hopefully make the postponed date!
Satruday May 6th
9.00a-10.00a --SqEvoVIII-- XedeFlash/Smart Xede/2 maps ***PAID***
10.00a-11.00a --SpyderBite-- XedeFlash/Xede ***PAID***
11.00a-12.00p --TammieNAndi-- XedeFlash/Smart Xede/2 maps ***PAID***
12.00p-12.30p LUNCH --probably pizza--
12.30p-1.30p --pter_drgn-- XedeFlash/93 & 110 maps for Xede/LC & NLTS enable ***PAID***
1.30p-2.30p --smokedmustang-- Custom pump & meth map for V390
2.30p-3.30p --EvoSTL-- XedeFlash/Xede/1 map ***PAID***
3.30p-4.30p --Silencer-- XedeFlash/Smart Xede/3 maps + LC enable ***PAID***
Sunday May 7th -->Starts at ~9.00a
1st --Ludikraut-- Verify SMART works, 1 race map, 1 pump map ***PAID***
2nd --Gashero--
3rd --WhiteEvo05-- XedeFlash/Smart Xede/2 maps ***PAID*** ???At the moment very questionable...depends on how work goes May 3rd???
THE FINE PRINT:Times above are approximate as some won't take as long as others. If your time slot does not work out with your travel plans, please contact me, and I will do what I can to get you a time slot that does. If you are going to need 100 octane or C16 please let me know to ensure there is enough on hand.
AND PLEASE READ THIS BEFORE YOU COME TO DYNO: https://www.evolutionm.net/forums/sh...d.php?t=135665
PM me for questions and to be added to the list.
Hope to see a good turn out!
Andrew
Originally Posted by Silencer
Add me in #4 spot on Saturday. I'll need an Xflash+Xede+Smart+3 tuned maps.
Dave
Dave
Originally Posted by Ludikraut
If Shiv promises not to break my clutch on the dyno, I might attend... just to shatter some eardrums
l8r)
l8r)
Info needed....no BS! Switching to Vishnu.
I currently have the following: Al Flash, Busher 3" TBE w/high flow cat, magnacore, K/N, Walbro and dynoed out at 250hp and 270tq on a Mustang. I would like to add maybe 50 more reliable HP. I will not be tuning or changing maps etc....I am going to do mostly suspension upgrades from here on out...questions:
Xflash or xede? what does the passive boost do?
cams: HKS or GSC 264's (I have a credit at GSC)
cam gears: Can I use Vishnu's cam gears if I use the GSC cams?
Set me straight! I need to get squared up by April 29th in St. Louis...
Thanks in advance!
Thanks in advance!
