FS: Exedy Triple, AMS VSR+, Built Head, Jun 272's, Quaife LSD, ETS 4" IC, and more!
Sold the car so these parts have to go.
Please help me clean out my garage, all items are priced to move! Just add shipping and PayPal fees.
Custom 3" Exhaust: $100
Used for approximately 70k miles, but still worked great when I pulled it off of the car. It is all stainless steel piping with slip fitting connections. The test pipe includes a two bolt flange to bolt up to any two bolt downpipe. Shipping will not be offered on this item at this time. Local pickup only.
Stock rotor set: $150
8k miles.
Coolant Overflow: Just pay shipping.
Jun 272 Cams: $400 Sold!
These are for an Evo 8 and have approximately 8k miles on them.
AMS VSR: $400 Sold!
This AMS VSR is flanged for a stock ported 65mm throttle body and comes with the support bracket and oil dip stick tube. It has approximately 10k miles on it. It polishes up very nicely.
Turbo Trix Upper Intercooler Pipes plus Tial 50mm BOV: Sold!
The TTr UICPs are stainless steel piping and will include the couplers and worm clamps. The piping is flanged for the included Tial 50mm BOV.
Wiseco Stroker Pistons with Oliver rods: $300 for the set Sold!
Only 2k miles on the pistons. The rods have approximately 10k miles on them. The pistons are a set of Wiseco stroker pistons with the heavy duty wrist pins. They have a bit of carbon build up from running rich, but will clean up nicely. I started to clean one up so you can see that they still look great. The rods are Oliver rods and came off of my 2.3L that spun bearings. Two of the rods suffered spun bearings and the other two were perfectly fine. Because of this, the cross hatch is worn on those two. They may still be good. In the end, for $300 you get a good set of slightly used pistons and walk away with possibly a good set of $800 rods!
Exedy Triple Metallic Clutch: $1400 Sold!
This is practically brand new with only 500 miles on it. The discs all measure 4mm which is the same measurement they come when new!
Evo 8 Turbo Trix Racing Built Head: $800 Sold!
This head was fully built to race specs by TTr to include a 5 angle port job, 1mm oversized valves, and dual valve springs. It has 86k miles, but only 2k miles since it's been built. The carbon build up was from running way to rich at cruise. The cam caps are included. I also have the thermostat housing and I may have a cam sensor housing if you need them.
Quaife LSD : $480 Sold!
The LSD is for an Evo 8 non-ACD t-case and has approximately 8k miles on it. Pulled from my working t-case.
ETS 4" Intercooler: $350 Sold!
Only 2k miles.
HKS DLI II: $175 Sold!
Will include the harness.
Fidanza Cam Gears: $100 Sold!
These are for an Evo 8 and have approximately 10k miles on them.
ARP Studs Sold!
Head Studs: $50
Main Studs: $35
They both have about 40k miles on them. I used these when I rebuilt a stock motor with a set of drop in rods and pistons, and they came off that same working motor before I sent it off to get built as a 2.3L.
Stock Cylinder Head: $250 Sold!
The stock head has roughly 40,000 miles on it. It was on my car when I melted the number 2 piston ring lands. This left some light aluminum deposits on the head that should clean right off. Other than this, the head is in excellent condition. This will make a perfect head to send off for a build.
Set of Stock Output Shafts: $100 Sold!
Approximately 12k miles
Stock Front Axles: $200 for the pair Sold!
86k miles.
Stock 2.0L Crank: $100 Sold!
Has approximately 40k miles. I pulled this crank from my perfectly running 2.0L before sending the block in for a 2.3L build.
Alternator: $50 Sold!
86k miles.
Stock Rods and Pistons: $50 Sold!
Will also include a never used set of ARP rod bolts.
Plate that bolts between transmission and block: Just pay shipping. Sold!
Starter: $50 Sold!
86k miles.
Stock Coil Packs with Wires: $50 Sold!
The coils have 40k miles on them and the wires only 2k.
Please remember, all prices will be plus shipping unless otherwise agreed upon. If you will be utilizing PayPal for payment, price will be plus fees. All items are sold as is, but please contact me if you have any issues with any items purchased once you receive them. After 1 week, all sales will be considered final.
If you are interested in a package deal, please PM me what items you are looking for and I will give you a great deal. I'm looking to move all these items out of here and the more you want, the better the deal you will get!
For more pics of the items I have for sale, please visit my Photobucket page here and don't forget to check out the sub-albums and other folders,
Items For Sale Pictures
As always, thanks for looking and if you have any questions please post up or PM me!
Thanks,
Barry
8k miles.
AMS VSR: $400 Sold!
Only 2k miles.
ARP Studs Sold!
Head Studs: $50
Main Studs: $35
86k miles.
86k miles.
Starter: $50 Sold!
86k miles.
Thanks,
Barry
If anyone else would like the same, please let me know and I'll get them posted.
