Fs: Evo 8/9 custom, coated& ported intake manifold=====>>>>
update: 3-1-13 BOTH MANIFOLDS SOLD. thanks for looking.
I have two intake manifolds I am selling. both were intended to create a more custom look. Each were ported , and have shaved plenums . One has been powder coated and the other fully shaved and polished. the polished one has more work put into it & is still on the car so it will be available shortly. details on that later. All work was done at local shops here in Las Vegas. check out the pics below. Please keep all negative comment to yourselves. Thanks for looking. Alfredo
FIRST MANIFOLD <<<<========== SOLD========>>>>
-- runners were gasket matched
-- TB opened for 65mm TB
-- Plenum has been shaved of all EGR /harness mounting points (JDM look)
-- Waffle pattern on the tops of runners were shaved.
-- the front two vacuum nipples are straight cut
-- Powder coated (wet Black)
-- Included is an EGR block off plate
-- what you see is what you get
-- PRICE: sold
02-26-13
1. top view
2. TB/ EGR side
3. bottom view
-- PRICE: sold
02-26-13
1. top view
2. TB/ EGR side
3. bottom view
The other manifold as stated before is currently on the car. I have taken a quick pic of it and also have an older pic of when it was being worked on .(off the car) more pics to come once it is off. please note. all vacuum nipples have been deleted. and the PCV fitting has been welded shut. Again please keep this thread clean and free form negative comments. Thank you
SECOND MANIFOLD
-- runners, gasket matched
-- plenum has port work and runner dividers have been shortend
-- Waffle pattern on the tops or runners were shaved
-- front two vacuum nipples have been deleted. (welded closed)
-- NO provision for PCV hose ( welded closed)
-- Only vacuum provisions left were FPR and Brake booster
-- Polished finish 8.5/10 has light scratches
-- PRICE: SOLD shipped===>>NOW: SOLD for manifold alone
EDIT: Will entertain trades for weight reduction mods. or FB 70mm TB on this mani
1. on the car
2. under construction before buff/polish job
got some pics today of the manifold off the car. here are the pics of the manifold plenum and runners. bottom side and TB side not polished. just brushed look
PICS BELOW
SECOND MANIFOLD
1. on the car
PICS BELOW
LOTS of interest on the black manifold. but nobody has committed . STATUS STILL AVAILABLE.
status update 2/26/13 sold black manifold
<<<<<<=====LINK FOR PICTURES TO THE SILVER POLISHED MANIFOLD IS UP====>>>>>
I work 6am-3pm PST so I don't check this till after work . TEXT the number above for faster respose
BUMP price drop on the silver / polished manifold $250 for just the manifold
. NO vacuum nipples
NO PCV nipple
not polished
plenum port work
not polished / with egr block off
. NO vacuum nipples
NO PCV nipple
not polished
plenum port work
