Cleaning out garage
Cleaning out garage
Just trying to clean up make an offer on any of these parts. Please include shipping and paypal fees in your offer.
Brand new ETS 3" Speed Density Intake with K&N filter powder coated flat black
FP HTA 3582R buschur cast exhaust manifold
FP HTA 3582R T31 buschur turbine housing(just back from FP rebuild)
BNIB ARP main studs PN 207-5401 fits all 4G63 and 4G64 motors.
Tail waste gate springs 1 small yellow 1 large green
STI 1.3 bar radiator cap
Turbo just came back from a fresh rebuild at FP with 0 miles mechanically went to a larger turbine housing and custom tubular manifold as I removed my A/C this setup was designed specifically between FP and Buschur to spool quickly and fit with a full A/C system.
Feel free to low ball the following parts
Coolant overflow tank with lines
Autometer 30-0-30 boost gauge w/column mount for gauge needs two screws, velcro or whatever you want to mount it
Stock air box and filter, missing a clip.
passenger side airbag
center console (no shift boot or bezel) needs paint
stock radio. missing a knob
rear window brake light cover
stock cams
spark plug cover
stock intake tube MAF and Buschur 3" cone filter
fan with harness clips
stock DV
A/C lines
A/C Compressor
BNIB greddy kevlar balance shaft belt
weapon r catch can no mounting bolts, hoses are dirty
Set of tail lights got ripped off by an EvoM member said they were IX tails and I traded him a perfect set of VIII's. Got them took off the vinyl and they were a set of poorly painted VIII's. So they will need to be painted correctly or overlayed using vinyl. The lens is the problem not the inside, mechanically good condition with all bulbs.
I also have some misc. cables and stuff for cobb accessports.
stock cams
spark plug cover
stock DV
A/C lines
A/C Compressor
cdupont03
Jul 2, 2014 03:14 AM
cdupont03
May 4, 2013 02:31 PM
cdupont03
Feb 28, 2013 08:40 PM
