F/S - Precision 46mm WG, T-67 P-trim DBB, Sparktech Pro CDI, Innovate WB, etc..
feel free to make offers.
open to trades on the following:
- HTA3586 turbo
- PTE 6266 or 6466
- Evo 9 Front bumper mesh ( the one above the intercooler mesh specifically)
***** Turbosmart dual-stage boost controller, was used to switch between 93-pump and e85 boost levels and work perfect - http://www.turbosmartusa.com/product/dual-stage. will include dash mounted switch, and was used approx 2k miles. $170 shipped/ + Paypal.
***** Precision 46mm wastegate, bought when they first released them a few years ago and black coloring faded off. works perfect never an issue, comes with all 5 standard springs ( sm 1.5psi, med yellow 3psi, med red 6psi, lg green 9psi, and lg blue 18psi) no springs are installed so you can choose your level. Also includes unused inlet and outlet flanges$215 shipped/ + Paypal.
***** T67 P-Trim DBB turbo approx 2k miles since i got it back from PTE for a refresh, excellent shape, does come with a .63ar hotside w/ a 2.5" 4-bolt outlet. made just over 700 on e-85 with this in my car w/ a 2.3L stroker, has 6an fittings for the coolant line and i will include the corresponding hose and hose ends. $750 shipped/ + Paypal.
***** Weld-on AN fittings, all brand new 2 vibrant - 8an steel fittings, 1 vibrant - 6an steel fitting, 1 vibrant - 6an aluminum fitting, and 1 aeroquip - 8an steel braze fitting. $10ea shipped/ + Paypal.
***** OEM front member, no engine mount included$85 shipped/ + Paypal.
***** ProSport 80mm Tach works perfect - http://prosportgauges.com/80mm-tachometer.aspx, and was used approx 2k miles. $95 shipped/ + Paypal.
***** OEM Coolant overflow. $17 shipped/ + Paypal.
***** Brake line Coupler, new, i used this same adapter to connect between my QM Hyd release bearing and my SS upper clutch line. $10 shipped/ + Paypal
***** OEM Fuel Pressure Solenoid, 20k miles, excellent condition, $12 Shipped/ + Paypal
***** Stock Engine Bay Fuel Feed and Return Line. $20 shipped/ + Paypal
***** OEM Crankshaft Timing Sprocket, excellent cond 20k miles, $20 shipped/ + Paypal.
***** OEM Crankshaft Sprocket, excellent cond 20k miles, $20 shipped/ + Paypal.
***** OEM Mitsubishi Crank Pulley Center Bolt & Washer excellent cond 20k miles, $12 shipped/ + Paypal.
***** OEM Oil pump sprocket, has small chip as seen in second pic 20k miles, $17 shipped/ + Paypal.
***** OEM Crank Trigger Plate excellent cond 20k miles, SOLD shipped/ + Paypal.
Feel free to PM me with any Q's, offers, Paypal Is hockeystar33@msn.com. ***** All Prices are OBO *****
More parts to come, Thanks
- HTA3586 turbo
- PTE 6266 or 6466
