Mark this thread as Sold
Old Parts from evo 9 MR
Meth Kit/ NX CO2 Sprayer and Old Parts from evo 9 MR
Name your price, Trying to clean out the garage. These are old parts that were removed from the car during the last build or parts not used from the build. all parts listed with number of miles of use.
All parts are best offer.
2X 2.5Gal Devil's Own Tanks/Cooling Mist Meth Injection Pump Kit - Kit comes with check valve M10 injection, 40ft of hose, all fittings, pump has brand new seals. both tanks are sumped to prevent sloshing and have tank taps installed. THERE IS NO INJECTION CONTROLLER. But I do have the 52mm gauge casing for the cooling mist controller for an additional charge. also have one set of tank mounting brackets.
Nitrous Express Nterchiller CO2 Sprayer. Comes with touch on/off switch. Push button and boost switch for manual or auto spray. Spray bar and solenoid. about 20 ft of Stainless Steel braided hose. and Tank adapter fitting
C02 Tank and CNC machined aluminun tank bracket
Stock MR bilstein Springs-45k
Robispec rear springs- new
Clutch slave cylinder-45k
Forge BOV Recirc with 3 Springs-20k
Agency Power Crank Pulley- sold
GTspec Oil Filter Adapter w/extra fittings- sold
6spd shifter cables w/torque solutions bushings-5k
Modified short throw 6spd shifter- 45k
2.75in throw versus 4in stock. its nearly strictly race though because it interferes with the center counsel
https://www.evolutionm.net/forums/ev...r-shifter.html
stock rear floor mats-45k
stock radiator stays-45k
the shifter was modified following my how to post on here. follow link above. i
