Mark this thread as Sold
MAP/HeadGames/ETS/TiAL/Buschur/OEM/FIC/Mil.Spec
Old Jun 4, 2011, 08:04 PM
mayberry's Avatar
I have a bunch of miscellaneous brackets, hoses, couplers, wiring, mounts, and so on. If you need something you don't see, just ask.
SHIPPING NOT INCLUDED IN PRICES UNLESS NOTED
WHEN SENDING PAYMENT, LET ME KNOW WHAT YOU BOUGHT IN THE NOTES!!!!!!!!!
Well, I got married recently and I have two kids. I sold my Evo but kept my build parts. I decided that having a fully built Evo really isn't feasible at this point in my life and I'd rather have the money in the bank then sitting in the basement. I don't need to sell these parts so the price listed is pretty firm, but I am willing to listen to reasonable offers. Thanks for looking. Any questions please feel free to ask.
Also, if the item listed does not have pictures, that means its sold.
PAYPAL USERS PLEASE ADD THE 3% WHEN MAKING PAYMENT
This is just the first round of parts, I'll be updating this thread as I have a ton of stuff I don't have time to list it all tonight.
Defi mechanical boost gauge. Great shape. Works perfect, has the pigtails for electrical hook up. From what I can gather its rather rare. Matches the Evo interior perfectly. $75 shipped
Innovate LC-1 wideband, comes with one good sensor and a brand new sensor, all the logging cables and even the usb to serial cable. Perfect working order. $180 shipped.
OEM upper timing cover $2
0 and OEM NEW lower timing cover SOLD both come with gaskets. Protect your investment.
Front motor mount bracket $20 flywheel dust shield SOLD to MagicManRed
OEM starter, 50k, good condition. $40
OEM MAP sensor $15 TPS sold to elhalisf
Brand new OEM throw out bearing SOLD, Vehicle speed sensor $30, Reverse light switch $10, Clutch fork and springs SOLD to TA ACE, any other item, make offer.
OEM front subframe brace with powerflex motor mount.sold , $30 plus shipping for the brace.
OEM motor mounts, good shape, 43k on them. $20 a piece.
AEM fuel rail with FPR, solenoid, fuel rails spacers and new hardware. I also used some SS line and band clamps for the small hose. Adds a nice touch to the engine bay. $80 shipped
AC mount bracket. $15
BNIB OEM oil return line $35
OEM Serpentine belt idler pulley, 2k miles, SOLD OEM radiator brackets $10 OEM water pump pulley $10
OEM coils and new wires. $30
FIC saturated (High Z) 1100cc injectors. Comes with o-rings and quick release pigtails. You don't need to solder in the new connectors, they're just a quick release style. Your stock evo harness will work just fine. I am also including a resistor box bypass plug so you don't need to cut up your resistor box. SOLD TO AreSTG
05 Evo transmission case and bellhousing. No gears. Just the case/bellhousing. I know this came out of a car with an active center diff, but should fit 03/04 cars too. sold to elhalisf
ETS short route Upper intercooler pipe with TiAL flange. Will not come with the Tial QR. But will come with couplers and t-bolt clamps. Its short route and for the stock manifold or any manifold that still retains stock throttle body location. SOLD to HEART_FITMENT
OEM alternator. 50k miles SOLD to boostlue
OEM AC compressor. 50k Perfect condition $50 shipped. SOLD to boostlue
MAPerformance built Long Rod 2.0 OEM Evo8 4G63 block and crank with Manley lightweight H-Beam 156mm rods, Wiseco 85.5mm 9:1 Compression pistons, ACL Race bearings, ARP main studs, OEM front cover and balance shaft delete kit. It can handle 650whp on a daily basis and as much RPM as you want to throw at it. It was built with that in mind. Hence the lightweight rods and pistons. SOLD to Derek2gspyder
OEM Evo8 Master Gasket Set SOLD TO JDMSEGO
HeadGames Motorworks built cylinder head. It has all the bells and whistles. From the port work to the awesome valve job. Dave really doesn't have any gimmicks, his heads can be found from super fast Supras to some of the fastest Hondas out there and Sheps personal Talon, you may have heard of it, lol. He has a ton of R&D into making a port that maintains mid-range and still has sick power out the top. It has stock size valves to retain spool, the only time its recommended to go over sized is when you're nearing 1000whp or above. It has Ferrea Competition Plus valves and Ferrea dual valve springs, seats, retainers, and valve locks. Supertech valve guides and seals. I will include a set of the ITM revised no tick lifters and OEM Evo rocker arms. I don't need your core,SOLD to JO EVO
JM Fabrications small battery kit with new PC680 battery with post kit. No miles on the battery and has been stored on a battery tender.The tray will polish up nicely. SOLD
ETS Custom 3.8" Garrett Core intercooler. I had ETS build this for me and it couldn't have turned out any better. I wanted the Garrett core and I also wanted the craftsmanship, fit, and finish that only ETS can offer. Comes with clamps, couplers, and crash beam spacers if you want to keep that thing. This has never been used or mounted. SOLD to z33c
MAP oil cooler. Comes with the lines already assembled and brackets ready to bolt onto your EVO. Not pictures are the fittings that go into the oil filter housing. Those will also be included. When map sends these out, the lines aren't pre-cut or assembled. Neither are the brackets. This will be ready to pull your old one off @ the brackets and bolt this one directly on. No swapping hardware. Comes the Setrab oil cooler. SOLD
Greddy Ti full titanium cat-back exhaust. This thing weighs about 11lbs. Comes with hardware and vibrant gaskets. I love the sound of this exhaust. It sounded so mean with my 2.4 and Comp 280 cams. I will include the o2 sensor and spacer. SOLD to GEJEN
Fludiampr harmonic balancer with ARP bolts. I used this for about 2800 miles. Its in perfect working order. The ARP bolts are brand new. sold to Svendiesel
Timing idler and tensioner pulleys have 2k miles on them, the roller rockers aren't for sale as they go with the head, make offer any of this stuff.SOLD
ARP exhaust manifold studs, used for 2800 miles. Great shape. Sold to Pepe Le Pew
MAP ReV3 intake manifold. No coating. Brand new, never mounted. I don't need your core. SOLD TO TTKID
Mil.Spec ported 65mm throttle body. Used for 2800 miles. Perfect condition, comes with IACV and throttle position sensor in good working order. I don't need your core. SOLD TO CoachG
Powdercoated glossy wrinkle black. Fitted for -8AN lines to the catch can. The hoses are fitted to mount the catch can on the master cylinder. The catch can alone sells for $100 from AMS. SOLD to OneNastyMR
Buschur Racing Baffled oil pan. This was a used pan and sent in for the baffling service. No rust, no debris 110% clean and ready to bolt on. Still sealed in the bag so no dust has gotten in it. I don't need your core. Sold to Svendiesel
SpoolinUp coil on plug ignition. Carbon Fiber mounting plate. These things have proven themselves time and again. Used for a short period of time. Sold To elhalisf
OEM mitsu hydraulic tensioner. Used for 2800 miles. Great shape. Has pin in it for install. SOLD
Cosworth crank scraper with instructions and hardware. Never used. SOLD TO NJ9MR
Five OEM oil filters and drain plug crush rings.SOLD
Unopened Gallon OEM Diaqueen SOLD
OEM evo8 water pump and gasket Sold to Derek2gspyder
OEM oil filter housing gasket sold OEM drivetrain train crush washer sets sold OEM front main seal $5 OEM intake manifold gasket sold MISC other gaskets make offer on any of the turbo oil and coolant lines and hardware.
OEM thermostat SOLD
OEM Evo 8 water pipe. I purchased this because I'm **** and mine was rusted. SOLD
MISC. -8AN fittings. SOLD
OEM heater hoses. come with oem clamps. 2k miles. sold to elhalisf
Oil filter housing with new OEM gasket dipstick and tube SOLD
OEM serpentine belt tensioner, SOLD
Whiteline Steering Precision kit (steering rack bushings) SOLD
Used MAPerformance H11 tool steel headstuds. These are the ones that are on the drag car. Only torqued once to 95ftlbs for 2k miles. Always lubed when not in the car and will come with a new packet of Moly lube to torque them. I checked with MAP and they can be re-used. SOLD
Buschur Racing clutch fork stop. Keeps your throw out bearing from popping out during quick shifts. sold to elhalisf
BeatRush license plate bracket for Evo 8 front bumper. Ditches that big ugly plastic thing. Comes with all hardware needed to mount. SOLD
Torque solutions exhaust hanger bushings. Brand new. SOLD
OEM front axles, 50k miles. No clicks or leaks. SOLD TO EVO.TINO
Works Crox Plate 2 (subframe brace) SOLD
Tactrix Cable and flashing adapter. SOLD
Rally Armor Mud flaps, comes with mounting hardware SOLD
AMS upper and lower clutch lines (2k) with Slave cylinder with 50k on it. SOLD
SPAL slim fan with the EVO fan controller already wired up and mounted to it. Just plug and play, comes with BRAND NEW mounting hardware. All the hard work is done. Sold to elhalisf
Unknown brand Springs and retainers. Will also include the seats. These are definitely aftermarket, not sure what brand. Dave@headgames said they were in good condition and look to be Supertech but wasn't 100% sure. SOLD
OEM injector resistor box. Sold to SvenDiesel
Gates Racing timing belt. 2k miles. Great condition. Never crimped or abused. No oil or solvents on it. Always dry. SOLD
Works Front strut tower brace. Really nice piece. 2k miles SOLD to Z33C
Resonator muffler with welded flanges to take position of the test pipe. I believe the muffler is made by vibrant.SOLD
HKS plug and play harness for Evo 8 and 9. Apexi turbo timer.SOLD to Z33C
OEM input shafts. 50k miles. Great condition. Sold
TiAL aluminum BOV flange. Fits TiAL Q, 50mm, Alpha Q, and QR sold to elhalisf
Buschur underhood shifter cable bushings. SOLD
BLE manual timing belt tensioner. High pressure valve springs and big cams can take its toll on the hydraulic unit. I learned that back in my Honda days. A manual tensioner if set properly will outlast and outperform any hydraulic unit. sold to BenderRodriguez
mayberry is offline
Old Jun 4, 2011, 08:54 PM
blaze-619's Avatar
Bump for nice parts and good prices.
blaze-619 is offline
localtoys73's Avatar
love the parts man. I really want that headgames head. Its about the only thing I didnt do in my build. I would have to get a ton for my head in order to pick this one up. Mine is built but not like yours. Having money in hand would be nice to. I have been thinking about getting rid of mine as well.
localtoys73 is offline
Old Jun 4, 2011, 09:46 PM
AboodsEvo's Avatar
nice parts! Does the gauge come with all the hardware needed?
AboodsEvo is offline
Old Jun 5, 2011, 06:45 AM
Boost_Inspired's Avatar
damn wish i had the money for the rev 3 mani , nice parts list man gl with the sale
Boost_Inspired is offline
Old Jun 5, 2011, 07:01 AM
CoachG's Avatar
I want the TB! Shoot me a pm with payment info.
Cheers!
CoachG is offline
Old Jun 5, 2011, 07:02 AM
vmrevo9's Avatar
GLWS! nice list of parts.
vmrevo9 is offline
Old Jun 5, 2011, 07:21 AM
mayberry's Avatar
It has the pigtails in the back of it for the electrical hook up and I can supply you with the vacuum line. You would just need your own gauge pod.
Cheers!
PM sent.
To everyone else, thanks for the kind words.
mayberry is offline
Old Jun 5, 2011, 08:28 AM
boczo777's Avatar
any turbos??
boczo777 is offline
mayberry's Avatar
I've added more stuff, but don't have everything listed just yet. Thanks for looking.
mayberry is offline
Old Jun 5, 2011, 01:56 PM
Trigger390's Avatar
PM sent on COP
Trigger390 is offline
Old Jun 5, 2011, 03:21 PM
Kidloco51's Avatar
The intercooler is tempting.....
Free Bump
Kidloco51 is offline
Old Jun 5, 2011, 07:56 PM
mayberry's Avatar
All PM's replied. Thanks for the interest.
mayberry is offline
Old Jun 5, 2011, 10:56 PM
Svendiesel's Avatar
Bump for my biffl. Shotty the fluidampr, oil pan, turbo timer and shifter bushings haha
Svendiesel is offline
Old Jun 5, 2011, 11:23 PM
mayberry's Avatar
No problem d00der. Parts list updated.
mayberry is offline
Quick Reply: MAP/HeadGames/ETS/TiAL/Buschur/OEM/FIC/Mil.Spec
