OEM / Stock - 18psi WG and DV
I didn't know that. This one does hold 18psi though. Maybe its not an OEM unit. This unit came with my FP Green but it looks nothing like the other FP 18psi unit I have seen so I figured it was an OEM unit. Either way, thanks for the heads up.
Im pretty sure thats an OEM unit, and it holds 18psi with the boost controller, but if you just ran a vacuum line to it then it would run around 11psi.
You can generally tell the OEM stuff from aftermarket by that goldish hue. Thats mitsu's coating for most of its mild steel stuff for protection. Not likely to see that in small quantity aftermarket gear.
