For Sale - Part Outs Parting out your car? Place it in here.
Whats left from evo 8 part outs guaranteed cheapest parts OBO
Old Jun 4, 2010, 10:23 AM
Torque07's Avatar
You name the price and its yours!
im going to vagas next week best offer on all this stuff i need the extra cash. I MEAN BEST OFFER!
This is what i have left from the 03 evo 8 tb. There might be more then what is listed
Body Harness- 100
Front Sub frame-150
Rear Sub frame-100
Pedal Assembly-75
Drive Shaft-100
All 4 Hubs-75 Each
Suspension Struts & Springs-250
Sunroof-150
Gas Tank-100
All Control Arms and Trailing Arms- let me know what you need
All Interior Plastics A+b+C Pillers Everything- let me know what you need
All Soft Brake Lines-40
Black Trunk (no wing)-100
Rear Seat-150
Cross Member-75
Passenger Axle-140
Shifter Base-50
Fuel Pump-50
Trunk Panel's-60
All Door Panel's- OBO
Wiper Motor- 50
Power Steering Pump (Bent Pully)-40
Air Bags- make offer i have both
Passenger Side Skirt- 150
Spare Tire- make offer
Washer Fluid Bottle In The Rear- 40
Passenger Lower Rocker-250
Driver Front & Rear Doors In Yellow- 100 each
These prices do not include shipping or paypal fee's.
There is a ton more here let me know what you need. I can get detailed pictures of anything you want to see.
Torque07 is offline
Old Jun 4, 2010, 11:30 AM
Evokid8's Avatar
pm me cheapest on rear passenger camber and toe arm
Evokid8 is offline
Old Jun 4, 2010, 11:38 AM
stryfetew's Avatar
pm for Apiller and cover for the drivers side inner door. the piece that pops off. also need an ashtray too. 30824
stryfetew is offline
Old Jun 4, 2010, 11:39 AM
stryfetew's Avatar
Forgot also need injector pig tails with retaining clips.
Old Jun 4, 2010, 04:48 PM
S2myEvo's Avatar
would you happen to have the passenger fender?
S2myEvo is offline
Old Jun 5, 2010, 08:03 AM
timmycat's Avatar
is there a lip for sale?
timmycat is offline
Old Jun 5, 2010, 09:11 AM
Torque07's Avatar
pmed. i dont have the passenger fender or the lip.
Torque07 is offline
Old Jun 5, 2010, 10:25 AM
MuslimEvoFreak's Avatar
Stock MAF and shifter base shipped to 60156? Cheapest price!!!
MuslimEvoFreak is offline
Old Jun 5, 2010, 01:52 PM
howell's Avatar
How much for the passengers hub assembly, and the clips that hold the insert under the hood?
howell is offline
Old Jun 6, 2010, 05:17 PM
LookThatsMe's Avatar
I need the slave cylinder, hard line and flex line from a 5 speed. Let me know if you have it...
LookThatsMe is offline
Old Jun 6, 2010, 05:55 PM
turbotime's Avatar
dont forget to save rear floor/strut tower wheel wells for me
turbotime is offline
Old Jun 7, 2010, 09:23 AM
Torque07's Avatar
I wont forget
Torque07 is offline
Old Jun 7, 2010, 12:27 PM
neonglh's Avatar
I am looking for the following items:
1. both the driver and passenger front wheel wells
2. upper plastic piece on the steering column (where you would mount a gauge pod, I want one with no holes)
3. the front center console (the one that goes around the shifter) (mine had a hole drilled in it for a switch)
Do you have any of these items?
Thanks!
--mark
neonglh is offline
Old Jun 10, 2010, 01:53 AM
eclipsegsx012's Avatar
do you have fuel injectors for sale??
eclipsegsx012 is offline
Old Jun 11, 2010, 10:44 AM
03lances's Avatar
Caution!!!!
I bought the ecu out of one of his many Fs threads, I paid for it on the 7th of Feb. Recieved it about a week later only to discover that the input insde the ecu that reads the crank signal is fried. I politely pmed him stating the issue, no response even though he had been active on here SEVERAL times throughout the time I waited. So I sent another asking him to please respond so we can find a solution to the issue with this. Again no response, despite once again being active several times so I sent another more aggresive pm stating that he needs to respond to me asap or I will have to file a claim with paypal as I still need an ecu and need to find one elsewhere and am not rich, $140 is alot of money for me. Low and behold I get a response within one hour imagine that. At first he stated that I must have hooked something up wrong and that to fix the issue all I have to do is clear the code. Before ever even pming him the first time I took all steps needed to confirm it was the ecu and not my car. I have my stock ecu that runs my car just fine however with my setup my ecu is insufficient and renders my car useless if I attempt to go into boost,(too much knock not able to properly tune with the tiny maps I have) anyways so I explain this to him and he insists that I must have a bad crank sensor my car runs fine its not the crank sensor. So he then replys that I fried it, I have no way to fry it the ecu is plug and play its two steps
1. unhook battery
2. unhook stock ecu hookup evo ecu
He did not test this before sending it out to me. I unfortunately cannot open up a claim with paypal due to myself checking the personal payment box instead of the goods and services box when sending the initial payment. I have done checking around and found 4 other people who had issues with parts purchased from this individual as well.
He did not and will not acknowledge that he sold me a worthless item and refuses to compensate for anything. In closing if you purchase something from this individual and have an issue upon receipt of the product do not expect any assistance with a return or refund. I now have a $140 paper weight... sweet
UPDATE: I also had this ecu tested by Aaron from English Racing who confirms its toast
03lances is offline
Quick Reply: Whats left from evo 8 part outs guaranteed cheapest parts OBO
