Fully Buschur Built 2.0 Longblock ..NYC
SOLD
HOLIDAY SPECIAL $ 5000 PICKUP !!!!!!!!!!!!!!!!!
Buschur Built 2.0 Longblock from Valve cover to oil pan, 0 miles on Engine Stand
Bearings (Rod, Main and Thrust)
Balanced, turned & polished Crank shaft
Buschur Racing Balance Shaft Eliminator kit
ARP Fasteners w/ headstuds
BR Spec Groden Aluminum Rods
BR Spec JE Tough Skirt Coated Forged Pistons
FluidAMPR Built Motor Engine Dampener
Complete engine gasket kit
New headstuds and all brand new belts & tensioners
Timing Belt & all new seals
Oil pan, oil pump, water pump is included
Brand New Cam angle sensor & L19s
Compression Ratio: 9.0:1
GSC S2 Mivec Brand New Cams
Custom BR dual stainless steel valve springs
BR titanium retainers
New Valve Seals
BR stainless .5mm over intake valves
BR stainless .5mm over exhaust valves
Stainless Oring around each combustion chamber
Complete port & polish job
Stainless Steel O-Ring
Mivec Valve Cover Included
NO CORE FEE REQUIRED!!!!
New Valve Seals
cant believe this is still for sale...buschur wont work with you even on just the bottom end...? maybe you can trade him your alum rod bottom end with a steel rod one? prolly sell much faster
