03 Evo 8 part out whats left
03 Evo 8 part out whats left lowerd price's
t-case- 800
Rear seats perfect- 200
Front drivers seat is messed up its twisted but the fabric is good, passenger seat is in good shape- 300
Act light weight flywheel, Act clutch disk with 3k on it both -200
Drivers side front and rear door in yellow-150 each
Dash harness- 75
Drive shaft- 100
Springs and struts missing 1 front strut- 200
3 door panels missing passanger front- 50 each
Rear subframe- 200
Passenger rear hub- 75
Front hubs- 75 each
All front and rear control arms- make offer
power steering pump-75
Alternator- 75
starter- 75
Front and rear swaybars- 50 each
Steering column with steering wheel with blown airbag- make offer
Trunk yellow- make offer
Weather stripping all doors- make an offer
I also have a ton of random interior parts just let me know what your looking for.
also a Center diff open face- 50 not from this car
These prices do no include shipping or paypal fees.
t-case- 800
Dash harness- 75
Drive shaft- 100
Rear subframe- 200
Front hubs- 75 each
Alternator- 75
starter- 75
i have pics no sound clips tho i guess you could go to youtube and type in perrin exhaust for and evo and see what comes up.
pm me your email's and i will get you a picture of whatever you want.
Caution!!!!
I bought the ecu out of this vehicle, I paid for it on the 7th of Feb. Recieved it about a week later only to discover that the input insde the ecu that reads the crank signal is fried. I politely pmed him stating the issue, no response even though he had been active on here SEVERAL times throughout the time I waited. So I sent another asking him to please respond so we can find a solution to the issue with this. Again no response, despite once again being active several times so I sent another more aggresive pm stating that he needs to respond to me asap or I will have to file a claim with paypal as I still need an ecu and need to find one elsewhere and am not rich, $140 is alot of money for me. Low and behold I get a response within one hour imagine that. At first he stated that I must have hooked something up wrong and that to fix the issue all I have to do is clear the code. Before ever even pming him the first time I took all steps needed to confirm it was the ecu and not my car. I have my stock ecu that runs my car just fine however with my setup my ecu is insufficient and renders my car useless if I attempt to go into boost,(too much knock not able to properly tune with the tiny maps I have) anyways so I explain this to him and he insists that I must have a bad crank sensor my car runs fine its not the crank sensor. So he then replys that I fried it, I have no way to fry it the ecu is plug and play its two steps
1. unhook battery
2. unhook stock ecu hookup evo ecu
He did not test this before sending it out to me. I unfortunately cannot open up a claim with paypal due to myself checking the personal payment box instead of the goods and services box when sending the initial payment. I have been doing some checking around and have found 2 other people who have issues with parts purchased from this individual who will shortly be filing claims as well.
Now that this is all out I want to add that I do not believe he knowingly sent me a faulty ecu but that fact still stands that he did and will not acknowledge this and refuses to compensate for anything. In closing if you purchase something from this individual and have an issue upon receipt of the product do not expect any assistance with a return or refund. I now have a $140 paper weight... sweet
1. unhook battery
What do you mean by shortblock "complete"? I need the following parts from the shortblock if they are still available:
1. timing belt
2. serpintine belt
3. tension pulley
4. timing belt idler tensioner
5. timing belt idler pulley
6. front case with oil pump and gears
7. oil cooler
8. water pump
9. oil pump
Can you post or either PM me the price for each? Thanks!
1. timing belt
2. serpintine belt
3. tension pulley
7. oil cooler
8. water pump
9. oil pump
