201 Motorsports APR & GReddy Exterior BLOWOUT
Greddy @ 201 Motorsports
Priced to move!!!
Greddy Front Lip Spoiler Evolution 8
Price: $SOLD OUT
Greddy Front Lip Spoiler Evolution 9
Price: $SOLD OUT
Priced to move!!!
Front Spoilers are the first point to receive airflow resistance; the design of the front spoiler determines the final handling of the vehicle. The GRACER front spoilers are designed to reduce airflow going beneath the vehicle and also direct air to critical areas such as the radiator and intercooler.
APR Performance @ 201 Motorsports
We have a few select items priced to move!
APR Formula GT3 Sideview Mirrors Evolution 8/9
Price: TOO LOW - PM ME!
APR Carbon Fiber Rear Diffuser Evolution 8/9
APR GTC-200 Adjustable Wing Evolution 8/9
When it comes to reducing aerodynamic drag to a car, the APR Formula GT3 Mirrors are an excellent choice. The APR Formula GT3 Carbon Fiber Mirrors are designed to give race inspired looks with the functionality of reducing drag and eliminating blind spots with wide angle mirror lenses.
Features:
# Carbon Fiber Construction: All APR Formula GT3 Mirror housings are reinforced with layers of carbon fiber sheets for weight reduction and added strength.
# Wide Range of Adjustment: Every Formula GT3 Mirror include a left to right pivot arm at the mirror housing with an adjustable ball stub rod to allow a wide range of adjustment.
# Aerodynamic Shape to Reduce Drag: These carbon fiber mirrors are compact and aerodynamically shaped for a low drag coefficient.
# Universal Billet Aluminum Bases for Easy Installation: Lightweight & durable billet aluminum mounting bases that can mount to any flat surface. Universal mounting bases are small enough to mount on door surfaces or your own custom fabricated mounting base.
# 5.5" Wide Angle Convex Mirror Lens: Convex lenses are used on both driver and passenger sides mirrors to eliminate blind spots. Blue anti-glare mirror lenses are included to reduce reflections from headlight glare during nighttime driving. Please note: Blue anti-glare mirror lenses found only on 5.5" wide APR Formula GT3 Mirror housings.
# Mounting Hardware Included: All screws, bolts and mounting gaskets are all included to allow you to install the APR Formula GT3 Mirror to your car.
Features:
Diffusers work in conjunction with other aerodynamic components of a car to help produce downforce. Because a car displaces air as it moves forward, the air molecules in the rear of the car get disrupted causing a vacuum of low pressure air.
To help channel the high speed air flow coming from underneath the car, diffusers redirects the high speed air flow to transition smoothly transition into the low pressure vacuum in the rear. This encourages a smoother flowing air flow underneath the car and allows better performance from other aerodynamic components such as aerodynamic wings.
Spanning 59.5 inches and a height of 10 inches, the GTC-200 adjustable wing offers the perfect amount of downforce for midsize and compact cars.
Computational Fluid Dynamics (CFD) analysis was performed on this wing to support validation of its aerodynamic design. The results of this analysis are available here.
Each GTC Series airfoil is composed of lightweight and durable carbon fiber composite. Supporting the carbon fiber airfoils are 10mm "aircraft grade" 6061 billet aluminum pedestals that come in a flat black powder coat finish.
