Just got my FP red installed and tuned at MFQ
Charlie did a all nighter to install my FP red, radiator, injectors, and neisei IC.
Mods: 2.3L stroker, built head, FP red turbo, Neisei IC, Tanabe dp, Denso 720 injectors. Made 382 whp on 91 pump gas at 24 psi boost.
something doesnt seem right all those mods, it seems a little low. I cant imagine that the different fuel and 6 psi of boost would make the difference between your numbers and the guy that had 565hp. maybe very very conservative. also it shouldnt drop off so much near redline. no doubt it is still fast.
Nice setup though and good luck with it!
Edit: Looks like you lost some power as it went a little rich right after 7000. Did they log knock?
Dudes, remember dyno dynamics dynos are the lowest reading dynos out there! We have several local here in MN and 380whp is the most I've ever seen out of a stock IX turbo.....high boost, cams, E85, the works! 380whp with 24psi on only CA91oct is freaking IMPRESSIVE!
Alky injecton/E85/race gas could easily let ya run 28-30psi and an extra 6-10* of timing, you'd be looking at 420whp on this dyno, which is well built 35R territory. VERY good power.
Can we get a full mods list please?
