TephraMOD V5.10
Old Aug 8, 2008, 07:07 PM
tephra's Avatar
Post TephraMOD V5.10
Hi All,
Well its been a long time in the making - finally it's out
CHANGES
- fixed AutoICS AND Valet intermittent enablement after flash - the occurance of this should be MUCH less
- fixed valet mode lockout
- added 1byte load
- included 2byte load(why?? ), 2byte rpm, and 2byte airflow MUTS - just tick the box in evoscan
- for 90550001 implemented the stat rev limiter
- fixed NLTS load threshold bug
- fixed issue where altmap_by_adc0f wouldn't change to altmaps if toggle switch was already ON when car first flashed
- added 2byte->1byte load mod
- added MAP averaging
DOCO
Add this to evoscan so you can log 1byte load:
Code:
<DataListItem DataLog="Y" Color="" Display="Load 1Byte" LogReference="Load1B" RequestID="41" Eval="1.2*x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="270" ChartMin="0" ChartMax="270" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Mode doco to come when I get time..
BIG WARNING
Whilst I have tried to test everything as much as possible it is up to YOU!!! to test each feature before driving your car around! If you notice any WEIRDNESS (including EcuFlash showing funny values for things) please post up so we can help you!
ROMS
88590015 TESTED by JordanS4, TouringBubble, xtremeIX
94170015 TESTED by evoredy, Jack_of_Trades, Magnumpsi
90550001 TESTED by cossie1, j3llyh34d, + others from OZ (fix version to fix valet+stat revlimit bug)
88580014 TESTED by me
96530006 TESTED by fixem2, Evil_3v0, derekste
88570008 FIX OUT TESTED by Cossie1, grayw https://www.evolutionm.net/forums/sh...&postcount=449
96260009 FIX OUT UNTESTED https://www.evolutionm.net/forums/6515345-post718.html
96420011 MUT FIX...UNTESTED
MORE TO COME SOON (couple of days - please be patient!! )
Lastly I have been accepting donations for my work, if you like it or get good use out of it please feel free to paypal whatever you can afford to donations@globalshare.net
Cheers
D.
Old Aug 8, 2008, 07:15 PM
honki24's Avatar
First post on a tephra thread ftw! 5.8 is working well enough for me right now so I may well just stick with that for now, but good job!
Old Aug 8, 2008, 07:17 PM
cossie1's Avatar
Good stuff Dave
Old Aug 8, 2008, 07:22 PM
tephra's Avatar
fixed
Old Aug 8, 2008, 07:42 PM
sub7's Avatar
Thx! I'll feedback my testing later
Old Aug 9, 2008, 04:30 AM
dolphin888's Avatar
Great news, 90550001 is back
BTW: Shortly, what is MAP Averaging option??
Old Aug 9, 2008, 04:52 AM
SkyNight's Avatar
Thank you Dave
Old Aug 9, 2008, 09:23 AM
j3llyh34d's Avatar
Please feel free to flame me if this is a dumb question........
9055001 isn't a 'standard' XML distributed with EcuFlash. Should I inherit or should I be asking nicely.......
Thanks,
j3llyh34d
Old Aug 9, 2008, 09:27 AM
JordanS4's Avatar
Yay
Old Aug 9, 2008, 09:55 AM
cossie1's Avatar
OK hope you don't mind me uploading these xmls on this thread dave.
This is my 90550001.xml with the edits done for v5.10 (ecuflash 1.31 and upwards). And my evo7base.xml
The ALS tables for 90550001 are included.
The MAF sensor is also scaled in Hz instead of g/s now too.
EDIT: Now updated for 90550001 v5.10 fix
File Type: zip
File Type: zip
Old Aug 9, 2008, 12:11 PM
veta's Avatar
Hi, your mods are gret, but let me ask how to make this mods to 88840013 rom...... EURO EVO9 ?
Old Aug 9, 2008, 02:29 PM
kkarim's Avatar
@veta, for the moment, you can use V5.5 (https://www.evolutionm.net/forums/sh...d.php?t=332778)
It was released on 88840017, which is fully compatible with 88840013 and 016.
K.
Old Aug 9, 2008, 03:20 PM
Oracle1's Avatar
88570008 please...
...Ohh I'm sooo impatient
Old Aug 9, 2008, 09:00 PM
evoredy's Avatar
EDIT: newb mistake...boost limit table was not maxed out to 319% load from 225%. ecu was initiating boost cut for 1000ms causing a violent fuel cut. see lower posts by JOT and cossie1. my bad.
use 94170015. it is VERY good at high RPM/LOAD. 03 EVO 8. (edited lol)
I tranferred all my stuff over from 5.8, re-checked (EDIT: apparently not), enabled NLTS this time (no biggie..disabled it later anyways) and wow.
the car cut off violently at 6500RPMS top of third (felt like harsh fuel cut). did it once in second around the same area. on 5.8, i'm hitting 320-330 load in those areas/higher gears. everything under was fine. switched NLTS off and same thing. always happened. i also have a rescaled maps with those loads if that makes any difference.
reflashed with identical 5.8 ROM and all is good.
Old Aug 9, 2008, 10:10 PM
Jack_of_Trades's Avatar
I'll test 94170015 in the morning and cormfirm if its the patch or just user error.
Quick Reply: TephraMOD V5.10
