E85 hints and tips…
I'm no expert, but as I understand it, the stock fuel rail is sufficient for stock frame turbos. However, the FPred is just out and I don't know of anyone running it on E85 who can confirm this.
The evolution (pun intended!!!) of stock framed turbos is turning around the EVO tuning community. Some might even say spinning it around (another pun !!!).
Few suggestions:
1) Might be better to say "Walbro 255 high output fuel pump" instead of "uprated fuel pump" because the Walbro is really the only fuel pump that has the flow capacity for E85 at high boost with a stock size turbo.
2) The PCV system serves an important function of helping to remove condensate from engine oil. Daily driven cars would be better off to keep the PCV system, and if a second vent hole is desired for high boost, then drill an additional hole in the valve cover.
3) I haven't seen any difference in idle tip-in response at idle between gasoline and E85. I'm running more timing than what you show in the idle tip-in timing cells. This topic would almost seem to be better suited to a E85 tuning thread though.
13. Consider more frequent oil changes, due to the extra stress of higher boost and the possible oil dilution from running 30% more fuel through the motor. For only $22.25 regular oil analysis might be a worthwhile investment. Oil Doc recommends Oil Analyzers.
that 22.25 price is only if your an authorized amsoil dealer..(from what i read on the website) otherwise its around 30 bucks. I have requested info from the oil doc to get these tests with no response. Therefore i use Blackstone labs. its 21-22 dollars and they send you the kit for free.
Few suggestions:
2. Changed the list to say track car.
3. What is a good timing number for the idle tip-in cells? Or a safe range?
Very nice thread!
I would like to clarify Dropspeed's comment concerning the increase in boost causing more power--obviously with the higher octane fuel you get to run more boost and even more importantly MUCH more timing! Timing is a key ingredient in making power!
Got another tip from experience at the track today in 95 degree weather
If you store E85 in a plastic container outside in the heat, E85 will evaporate much faster than gasoline. This evaporation will also cause pressure to buildup faster inside the plastic container faster. So, vent the containers frequently before too much pressure builds up or it'll spillout like a shaken up can of soda.
Nahhhh...
You just need the right contacts...
Also, AMSOIL utilizes ISO 17025 A2LA Labs which have the highest standards in the industry where your tests are totally duplicatible. Some Labs that may have been mentioned in this thread, may not have that ISO Rating which is why their Analysis may not be as consistent.
Also.... Coming in just a few days (Aug 1st) AMSOIL's new RD-30 (Donintator 10W-30 Racing Oil) will be available which, although Analysis is recommended, will be compatible with ALL fuels.... This does not mean that you don't have to worry about fuel dillution, it just means the oil will not break down from the dillution.
3 new Racing oils will be available and the TRO Series 2000 Racing oil will be gone.
The new oils are:
RD-20 which is a 5W-20 oil meant for qualifying.
RD-30, 10W-30 for tight clearanced high revving engines such as the EVO
RD-50, 15W-50 for the All Out Race Engines that need long distance durability.
Doc
Precisely. Unfortunately the average Joe cannot get the cheap pricing from oil analyzers directly. We have to jump through hoops to find a dealer or become a dealer, and then have them order them for us.
How bout you start to make them available?
IMO both labs give you quality results and if something is wrong with your oil it will show up on either report. I just have a hard time expending more time and money to get the report from the one lab.
