Evo 'For Sale' Exterior Styling Includes spoilers, body kits, tail lights, gauges, shift knobs, and other styling components.
Evo Hood Damper Kit (Nitrogen-filled) for Evo 8-10
Old Jun 27, 2008, 08:09 PM
Mike@Mynes's Avatar
[SIZE="2"]Mynes Performance has received our latest batch of Gas hood damper kits for the Evo 7, 8 & 9. Our kit has been redesigned to have stronger gas shocks than our competitors and it eliminates the "lazy" hood opening... This kit can be installed in about 10 minutes.
VIDEO Demo Added: http://www.youtube.com/watch?v=b2bvyj0Mam0
It's Carbon Hood safe !!!
Kit Contents:
- Gas Damper w/ Ball Stud & fastening clips (2)
- "Long" Brackets for fender (2)
- "Short" Brackets for hood (2)
- Lock washers (4)
- Washers (4)
Instruction updated on Dec 24, 2008!!!
Tools needed:
One rachet with a 10mm socket and a 12mm socket.
Method #1
Method #2
Install Instructions:
Method #1 - For Evo 7, 8 & 9 models
Installation Instructions:
1. Remove screw from middle of fender on Driver side.
2. Insert screw through the Long bracket (labeled "L") and attach lock washer behind the bracket.
3. Tighten screw back on to Fender - make sure the ball screw end is pointing towards the driver seat.
4. Remove the screw on the outer edge of the hood bracket with 12mm socket
5. Insert screw through the "L"-labeled short bracket and attach lock washer behind the bracket.
6. Tighten screw back on to hood - make sure the ball screw end is pointing upward.
7. Remove "fastening clip" from the skinny end of the damper.
8. Affix Ball Stud to the ball screw on the fender bracket, make sure the fitment is tight.
9. Insert the "fastening clip" back into the ball screw and rotate the clip until it snaps back into the body.
10. Remove the "fastening clip" from the other end. Compress the shock and affix the Ball Stud to the ball screw on the Hood Bracket. Rotate the shock (if needed) so the Ball stud & Ball Screw are in perfect alignment.
11. Insert the "fastening clip" back into the ball screw and rotate the clip until it snaps back into the body.
12. This is how it looks when properly installed.
13. Repeat the above steps on the passenger side; when done, this is how it should look
Method #2 - alternative method for Evo 8 & 9.
2. Remove the ball-screw from the SHORT black brackets and affix it directly to the fender with the large washer.
3. Remove the screw on the outer edge of the hood bracket with 12mm socket or wrench
4. Insert screw through the "R"-labeled LONG bracket and attach "lock washer" and "small washer" and tighten the screw; the "L" Long bracket should go on the passenger side.
5. Tighten screw back on to hood - make sure it's nice and TIGHT & the ball screw end is pointing upward.
6. Make sure the bracket is pulled all the way up to allow enough clearance between the stud screw and the hood bracket.
8. Affix Ball Stud to the ball-screw on the fender.
12. Repeat the above steps on the passenger side; when done, this is how it should look when it's installed.
13. Congratulations!!! You have successfully installed the Mynes Hood Damper Kit for your beautiful Evo!!!
File Type: jpg
File Type: jpg
File Type: jpg
Old Jun 27, 2008, 08:20 PM
Evoryder's Avatar
i might just have to invest in this.
Old Jun 29, 2008, 11:08 PM
Vostok 7's Avatar
MIKE! Hook me up man, I've been needing some of these for some time now
- Patrick
Old Jun 29, 2008, 11:17 PM
Mike@Mynes's Avatar
PM ya These things are great, don't have to worry about getting burn by that hot metal hood prop anymore
Old Jun 29, 2008, 11:35 PM
Vostok 7's Avatar
Yep! On my STi I just took the hood prop totally off when I had dampers Weight savings! All, what, 5oz of it!
- Patrick
Old Jun 29, 2008, 11:49 PM
EvoHung's Avatar
Interesting. Do you have a video of the hood opening? About how long would these last you?
Old Jun 30, 2008, 08:17 PM
evo_tiago's Avatar
free bump for you Mike. try to drop by one of this days.
Old Jun 30, 2008, 08:57 PM
tabio42's Avatar
Payment Sent!
Old Jun 30, 2008, 09:12 PM
phabaznbro's Avatar
i have a set of these from another vendor...i get the worst lazy hood ever...if these really don't do that...they are worth it...free bump
Old Jun 30, 2008, 10:50 PM
Mike@Mynes's Avatar
Originally Posted by tabio42
Payment Sent!
Thank you. Will ship it out tomorrow via UPS
Old Jun 30, 2008, 10:55 PM
Mike@Mynes's Avatar
Video Demo here: http://www.youtube.com/watch?v=b2bvyj0Mam0
This set has been on our Shop 9 for the past 7 months, and it's still working like a champ.
We know that things break and we are willing to stand behind our product with a ONE YEAR Exchange warranty (free exchange, excluding shipping) from the date of purchase. Pls keep your invoice for your record.
Old Jul 1, 2008, 01:03 PM
Vostok 7's Avatar
Now you guys need to make an engine damper
- Patrick
Old Jul 1, 2008, 01:14 PM
VtexGt3's Avatar
damn i really need a set of htese for my cf hood cause it bends when i just use the OEM metal rod... but not for carbon hoods.. ahhhhhhhhhhhh!!
Old Jul 1, 2008, 01:20 PM
mdsevo06's Avatar
Payment sent. Thanks for a great product, been putting this off for far to long.
Mitchell Shelton
Old Jul 1, 2008, 01:24 PM
Mulholland0132's Avatar
They look good. I may have to invest in a set of those.
Quick Reply: Evo Hood Damper Kit (Nitrogen-filled) for Evo 8-10
