Roof rack fitment found
Hi All,
As I've mentioned in other posts, I needed to figure out a roof rack fitment so that I can get my mountain bike to the trails. Mitsu USA doesn't offer one, and neither Yakima or Thule list a fitment at this time. Mitsu Japan has one in their catalog that is obviously a Thule, so the proper "fit kit" clips and feet pads obviously exist.
I had most of the parts for a Thule roof rack system already, so I went to my local bike shop and Gander Mountain with the car, a trace of the roof rail contour, and picture of the JDM rack and went through every kit that I could find to see if any matched up. In the end I found Fit Kit #2120, which is listed as being for '03+ Toyota Corollas which appears to be the ticket.
I test fit everything carefully and I think it is just about perfect. The angles and length on the clips match the Evo X's roof rails perfectly, and the feet pads are the correct width and have the right "shoulder" location, though to be absolutely perfect they would need to be slightly angled to match the way that the rain gutters angle outward a bit in the front.
There are markings inside the door rails that designate the center of the foot location, and if you look that section is slightly straightened in order to accommodate the clips. I covered the areas where the feet and clips touch the car with clear-bra material, cut the crossbars down to the fit nicely, and mounted it up. The fit kit comes with two slightly different styles of the clips. The only difference is that one set is very slightly longer. I used those in the front. It also comes with a set of "spacers" that position the clips up higher in the towers, but those were too high for this application so I left them out.
It's on there very solidly and nothing is digging in or binding anywhere, so I'm happy with it for now. When Thule releases an official kit I'll change over to that - unless of course they end up specifying this same kit...
I initially mounted up a fairing, but after thinking about how amazingly thin the roof panel is I removed it. I was concerned that the fairing might push down on it's feet enough at highway speeds that it could end up denting the roof. It looked better with the fairing on, but it isn't worth risking. Mitsu doesn't show the fairing in the JDM catalog, which might also suggest the fairing isn't a good idea.
I'll take some pictures and post them tomorrow.
--Josh
--Josh
Please Josh if you can post some pictures and comments about this, as I have the same problem (I actually don't own the X yet so it is an important buying factor). I usally carry 2 MBs and a windsurf... do you think the fit kit that you found is strong enough? I also have a Thule rack so I just need the fit kit.
Thank you!
Thank you!
I just replied to your PM with more details but forgot to mention that I won't be able to take any pics until I get back from the RallyCross in D.C. early next week. I'll take some good pics for you then.
No, as the feet rest on the black rain rail and the outer steel roof rails. I did take off the spoiler though, as it has four small pads that rest against the roof and I was concerned that it would dent the roof at speed - that roof panel is very thin.
I could try to explain how they mount, but it'll be easier to understand in pictures. My ride today got canceled, but I'll mount it up in the next day or two to get the pics for you guys.
Nothing is mounted permanently, when you remove the rack, which takes a couple minutes total, it is completely back to normal.
I actually went out and did the same thing, except i own a evo 8 RS. This kit fits pretty well on the steel door rails. so there isnt any part touching the aluminum roof.
One thing is you probably need 2 people to make it fit correctly i couldnt tension mine without having one side slide. but that might be not getting the correct bar width. But anyways it works with the Thule kit for the evo's roof profile.
Cheers
Cheers
I finally put the rack back onto the Evo this afternoon, and took a bunch of pictures. You can see how well the clips match the angles of the roof rails, and that the rubber pads fit onto the black rain rails nicely, but that to be absolutely perfect the fronts should have a bit of an angle on them to match the way that the roof rails curve outwards.
It's easy enough to put on and take off, and is solid once on. You might notice that I put some sections of clear bra material at the contact points just to be careful with the paint. It would be nice to have the spoiler on there, but I don't want to risk it putting too much pressure on the roof, as the support pads would rest on the aluminum section.
