Buschur Front Undertray Install
Old Apr 10, 2008, 02:33 PM
RevMoto's Avatar
Tools needed
  • Philips screwdriver
  • Drill
  • 5/16 drill bit
Step 1: Remove undertray. (Already a write-up on this so I am not going into detail)
Step 2: Line up the holes from your stock undertray on top of the Buschur undertray.
Step 3: Using a marker, mark all the holes that you are going to drill. This takes the guess work out of where they are going to go. Most of the holes are not needed but I did so anyways to add as much support as I could.
Step 4: Drill the holes using a 5/16 drill bit. You now are ready to put this sucker on.
Also buschur normally supplies a heat shield. I don't have it installed since my dp is wrapped.
Step 5: Line up the front holes first as they are the hardest to reach. The surface is not going to be completely flat so getting the factory locks in might take a little massaging.
Some intercoolers are not going to allow you to use a couple holes in the front because you don't have enough room to stick the locks high enough. You can either put this on with the bumper removed from the car or leave it alone like I did for convenience of removal in the future.
Step 6: Admire your work. You never have to worry about that dreaded stock undertray ever again.
RevMoto is offline
Old Nov 16, 2008, 11:50 AM
chaotichoax's Avatar
Discuss thread HERE!
chaotichoax is offline
mitsuorder
Sep 20, 2021 06:05 AM
YogSaahoth
Nov 10, 2016 02:49 PM
robertg
62
Feb 18, 2016 03:28 PM
TJung
May 9, 2015 11:04 AM
tanto
Apr 10, 2008 01:10 PM
Quick Reply: Buschur Front Undertray Install
