Evo Turbo Information
Old Aug 2, 2003, 05:27 PM
jemm's Avatar
Got some of this info from a brochure. Some of this may have been posted here before but here goes:
Evolution 1
Turbo = TDO5H–16G-7
Nozzle Area (cm2) = 7
Exhaust turbine = Inconel (steel alloy)
Compressor = Aluminium, 60mm wide
Evolution 2
Turbo = TDO5H–16G-7
Turbine = Inconel (steel alloy)
Evolution 3
Turbo = TD05H–16G6-7
Compressor = Aluminium, 68mm wide
Evolution 4
Turbo = TD05HR-16G6-9T
Nozzle Area (cm2) = 9
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
TD05HRA-16G6-10.5T (RS)
Nozzle Area (cm2) = 10.5
Turbine = Inconel (steel alloy), Titanium alloy (RS)
Evolution 6
TD05HRA-16G6-10.5T (RS/rs2)
Turbine = GSR - Inconel (steel alloy), Titanium alloy (RS/RS2)
Evolution 6 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
Turbine = Titanium alloy for both RS/RS2/GSR!
Compressor = Aluminium, 65mm (gsr) - 68mm(rs) wide
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
Turbine = GSR - Inconel (steel alloy), RS/Rs2=Titanium alloy
Evolution 7 GTA
Turbo = TD05-15GK2-9.0T
Nozzle Area (cm2) = 9.0
Compressor = Aluminium, 65mm wide
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM E8)
Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
RS/Rs2=Titanium alloy.
Evolution MR aka "8.5"
GSR = TD05HR-16G6-10.5T or TD05HRA-16G6-10.5T (Ti Alloy option)
RS = 6MT:TD05HRA-16G6-10.5T or 5MT:TD05HRA-16G6-9.8T
Nozzle Area (cm2) = 10.5 or 9.8(RS-5speed)
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels (see first pic). As the engine exhausts in pulses.. its supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
Old Aug 2, 2003, 05:53 PM
mayhem's Avatar
Wow jemm, good info! This should be stickied or added to the front page Evo information.
Old Aug 2, 2003, 06:00 PM
jemm's Avatar
Pic courtesy of Evo-7 of the UK MLR (http://www.lancerregister.com) site, showing the twin scroll exhaust entry:
Old Aug 2, 2003, 06:03 PM
jemm's Avatar
For those of us that want to know where the turbo designation is : Its on the intake side, aft of the tube leading from the MAS
Old Aug 2, 2003, 06:05 PM
jemm's Avatar
These last 2 pics are from Heave-Ho6's Evo 6 again from the MLR. On the 7 & 8 the space seems to be a little more cramped... I find it difficult to see the reading on my car.
Old Aug 2, 2003, 06:13 PM
jemm's Avatar
Thanks .... Check this out also (from the e7 brochure):
"In addition, optimization of the turbocharger by reducing the twin-scroll turbine nozzle diameter cross section (A/R) has resulted in a stable and consistent torque band that tops 350N-m (35.6Kg-m) in the 2,750 and 5,500 rpm mid-rev range. Not only does this make for outstanding driveability at normal speeds, it also delivers tremendously responsive, thrust in the back mid-range acceleration"
Old Aug 3, 2003, 07:04 AM
jemm's Avatar
Water cooled
I came across this in the jdm Evo 8 brochure and it kinda surprised me as I always thought the Evo's Turbo was oil cooled alone!
Thanks to Josh (ShapeGSX) for clearing this up for me:
"Yes, the Evo's turbo is water cooled. Oil cools it too, obviously.
You would probably have a hard time finding a non-water-cooled turbo on a production car these days.
Hell, even the 16G I have on my car (from an Evo III) is water cooled. ... the center section (where the bearings are) is actively cooled"
Old Aug 3, 2003, 07:08 AM
jemm's Avatar
Thumbs up Turbo dissected!
TD05HR-16G6-9.8T diagram:
Old Aug 3, 2003, 07:15 AM
jemm's Avatar
Center cartrige closeup
showing the cooling ports for the center cartridge:
Old Aug 4, 2003, 12:44 PM
timzcat's Avatar
I agree it should be a sticky.
Old Aug 6, 2003, 08:37 AM
Hypreshr's Avatar
Where can we get the titanium turbos and how much are they. I'd love to spool about 500 RPM's sooner.
Old Aug 13, 2003, 04:50 AM
ShapeGSX's Avatar
The H in TD05H stands for High Flow.
I lied about the turbo I have. Looks like it is from an Evo 1 or 2. I have a 7cm TD05H-16G 60mm.
I just bought an Evo III 16G, though. I should be installing it on Saturday. The Evo III 16G was just "discovered" in the US a little while ago. It has a better 7cm housing than DSM guys are used to. It is made of a better alloy (doesn't crack). The wastegate port is relocated for better boost control.
The compressor is also slightly larger than the big 16G that we have always got. But the compressor wheel is also lighter due to thinner blades.
Data:
http://www.slowboyracing.com/Mitsubi...omparison.html
Pics:
http://www.killwicky.com/images/080603/
Old Aug 17, 2003, 09:31 AM
jemm's Avatar
For the Evo 8's TD05HR-16G6-9.8T turbo, Vishnu found this on examination of the stock car :
"Boost pressures also met expectations with a whopping 19 PSI of peak boost, tapering down to 16 PSI by 7000RPM. As far as we know, this is more boost than any other currently produced turbo car."
Max flow rate/ HP = (505cfm) = ~375-400 HP depending on who you talk to for the standard Evo turbo 16g6 compressor wheel. The smaller 9.8cm2 housing will mean that the 7 and 8 turbos will not flow as much air as the V/VI's at high rpms. Low end torgue is improved however.
Old Aug 27, 2003, 03:50 AM
jemm's Avatar
Inconel 600
Density = 8470 kg/m3,
Tensile strength = 95 ksi,
Yield strength 45 ksi
Titanium
Density = 4507 kg/m3,
tensile strength 130 ksi,
yield strength 120 ksi
tinanium alumnide specs to follow....
This is the GSR vs. RS turbo's weight:
Old Aug 27, 2003, 03:54 AM
jemm's Avatar
From reports, it appears that the titanium turbo (more so than the inconnel version) does not react well to high boost levels with poor petrol. This happened to a guy who leaned-out on croation unleaded (?octane):
Quick Reply: Evo Turbo Information
