Titek O2 Housing, DP, Dress up, OKADA PROJECT Coil, OTHER GOODIES
Old Mar 13, 2008, 03:44 PM
500whp.com's Avatar
Exclamation Titek O2 Housing, DP, Dress up, OKADA PROJECT Coil, OTHER GOODIES
TiTek brand is distributed and tested by the leading retail/wholesale/tuner company in the in the nation, SP Engineering.
SP Engineering is best known for their over 1,000 WHP Supras, but they have also tuned, build cars that have been in over 15 magazines world wide, with over 40 feature cars. These cars include: 675 HP 97 Civic HB, 710 HP R33, the infamous Supra 7 (2JZ-GTE in a FD), Tein S-15, APR Performance Evo (Fast and Furious 3), MR-S, WRX STi, High End�s 800 WHP Top Secret Supra, Porsche 911, to 2003 Lamborghini Murcielago, and the list goes on�
With more than 10 years of experience in the market, and countless hours in the lab testing out TiTek products. The TiTek line is affordable, finely crafted (same material used in Lamborghini parts in the TiTek line), and wide power band power gains. Best of all, products are backed by a one year warranty (If approved a new item will be shipped out to you the same day that the warranty is approved).
TiTek 3' Down Pipe - Evo 8~9: PM for Pricing
Also include 3' gasket to Cat, Heat treated Bolt, Nut to Cat.
TiTek O2 Housing - Evo 8~9: PM for Pricing
Speed Series (60mm) (Long): Retail: PM For Pricing
Racing Series (45mm) (Short): Retail: PM For Pricing
TiTek CF Evo 8 Cam Gear Cover: PM for Pricing
TiTek CF Evo 9 Cam Gear Cover: PM for Pricing
TiTek CF Spark Plug Cover: PM for Pricing
OKADA PROJECT PLASMA DIRECT (PAT)
A revolution in ignition technology!!
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
Plasma Direct is made to a specific application. Please check Application chart to find the correct model for your car.
Highlights
・100% secondary current (Spark Amperage) increase
・4 Times Spark Energy Increase for the initial spark discharge
・Easy installation. Only replace stock coils to Plasma Direct.
・Compatible with all OEM components
・Compatible with OBD-II (On-Board-Diagnostics)
Mitsubishi EVO
Explosive Discharge Provides
・Top Engine Performance
・Aggressive horsepower
・Dynamic torque
・Lightning Response
・Bombing Turbo Boost
And accord with
・Fuel Efficiency Improvement
・Reduce Emissions
Oscilloscope Data
Comparasion of Ignition Secondary current on the same time scale.
The typical OEM type discharge. The Secondary spark current reaches a maximum of 60mA.
The Secondary spark current reaches over 140mA. Also, the multi spark oscillation is clearly seen.
Okada Project Plasma Blast Ignition Coils: PM for Pricing
500whp.com is offline
Old Mar 14, 2008, 02:12 AM
500whp.com's Avatar
TiTek
Old Mar 14, 2008, 02:48 PM
500whp.com's Avatar
TiTek downpipe, downpipe, down pipe, o2 housing, turbo outlet
Old Mar 15, 2008, 01:25 PM
500whp.com's Avatar
TiTek downpipe, TiTek downpipe, TiTek down pipe, TiTek o2 housing, TiTek turbo outlet
Old Mar 17, 2008, 04:52 AM
apeximprt2nr's Avatar
Do you guys know how much power the coil packs are rated for?
apeximprt2nr is offline
Old Mar 17, 2008, 05:08 AM
tkklemann's Avatar
Price of Carbon Spark Plug Cover, Cam Gear Cover, Red Short Lug Nutz to 29410...
tkklemann is offline
Old Mar 17, 2008, 08:41 AM
MasterNater's Avatar
Titek O2 Housing to 60545
PM Sent
MasterNater is offline
Old Mar 18, 2008, 06:31 AM
Anyone know?
Old Mar 18, 2008, 10:49 AM
500whp.com's Avatar
Its rated close to 1000 i believe
Old Mar 18, 2008, 10:54 AM
500whp.com's Avatar
all pmed and replied
Old Mar 18, 2008, 02:48 PM
1slowevo's Avatar
how much for the okada coils shipped to 02478?
thanks
1slowevo is offline
Old Mar 18, 2008, 02:56 PM
500whp.com's Avatar
thanks
YGPM
Old Apr 22, 2008, 09:49 AM
EvoNyMR136's Avatar
price on RED Speed Series (60mm) (Long) shipped to 11428
EvoNyMR136 is offline
Old Apr 24, 2008, 02:55 PM
500whp.com's Avatar
YGPM
