BorgWarner S256 Dyno Results!
Old Feb 25, 2008, 03:36 PM
Former Vendor
Keith-PURE Tuning's Avatar
Borg Warner S256 Dyno Results.
Test were performed at Pure Tuning on Mustang Dynamometer MD-1100-AWD-SE.
Dyno Graph 1
Car: 2003 Evo 8
Engine: 2.0L
Fuel: 93 octane
Turbo: Borg Warner S256 / Open T3 .55ar Stainless Turbine Housing
Intake Manifold: Magnus (Street)
Cams: Tomei Pro 260 / 11.5ex, 11.5in
Max Boost: 22psi @ 4500rpm
Atmospheric Temp: 92Deg
Relative Humidity: 2.7%
Dyno Graph 2
Car:2004 Evo 8
Engine: 2.3L
Fuel: E85 octane
Turbo: Borg Warner S256 / Open T3 .70ar Turbine Housing
Intake Manifold: HKS Kansai
Cams: Crane 280 / 12ex , 12in
Max Boost: 23psi @ 4800rpm / 26psi @ 5000rpm
Atmospheric Temp: 77Deg
Relative Humidity: 22%
Last edited by Keith-PURE Tuning; Feb 26, 2008 at 03:51 PM. Reason: Enter Cam Specs & Turbine Scroll
Old Feb 25, 2008, 05:55 PM
justboosted02's Avatar
nice numbers, looks like a monster street turbo
Old Feb 25, 2008, 06:37 PM
YellowEvilEvo's Avatar
on the second car, you can probably attribute 50 awhp to that 1700 dollar intake :-)
Old Feb 26, 2008, 12:15 AM
chuntington101's Avatar
need some pics of the setups now!
Chris.
Old Feb 26, 2008, 12:18 AM
EvoKnievo's Avatar
wow, pretty good spool for those numbers.
Old Feb 26, 2008, 01:37 AM
ONRAILS's Avatar
wow, that really shows the difference in intakes huh. I wonder how much more power the first car would've made with a stock one
Old Feb 26, 2008, 07:42 AM
shivaswrath's Avatar
pictures of it installed?
where can one acquire such a turbo?
Old Feb 26, 2008, 07:55 AM
thatsMR2u's Avatar
where these twin scroll or the bullseye t3 single scroll
Old Feb 26, 2008, 08:00 AM
FullOutPwr's Avatar
Right from their website. Click Me
Old Feb 26, 2008, 08:10 AM
mrdevo's Avatar
Did the housing really add that much lag despite having a 2.3l? Full spool went from 4500 to 4800 with a 2.3l, bigger housing, and intake manifold.
Old Feb 26, 2008, 08:12 AM
mitsuboost30's Avatar
Awesome cant wait to get my BW on the dyno...
Old Feb 26, 2008, 10:13 AM
Exciting News's Avatar
Thought the same thing. I figured the increased displacement would have offset the the housing and intake manifold size increase. Second chart looks a little peaky.
I like the first setup more.
My guess is that it's an open housing.
Old Feb 26, 2008, 02:57 PM
Former Vendor
The .70ar hotside caused a little of the later spool on the 2.3, but I did forget to put the cam info in the specs. The 2.3L was running some 280 Crane Cams and the 2.0L was running a set of 260 Tomei Cams which is the real reason for the difference in spool.
I'll have to look for pics of the two cars. Not sure if I took any?
Both turbos where standard open T3 turbine inlet.
I'll edit the specs to include the info you guys have brought up.
I'll say that the 2.0L reved crazy fast through the power band. I thought it reved fast on the dyno when I tuned it, but when I took it to the street, third gear is completely unusable because you run into traffic fast when 100mph comes in 2-3seconds.
Thanks for looking
Old Feb 26, 2008, 03:28 PM
Which Tomeis?
PonCams (low lift) or ProCams (high lift)? They both come advertised as 260.
Old Feb 26, 2008, 03:52 PM
Former Vendor
Originally Posted by Exciting News
Which Tomeis?
Procams 260 / 11.5
Quick Reply: BorgWarner S256 Dyno Results!
