finally got my FP HTA twin scroll gt3582R
Old Jan 21, 2008, 11:51 PM
riceball777's Avatar
well my forced performance t3 twin scroll HTA gt3582r came in today. t3 twin scroll .78 ar v band turbine housing. i'll be ordering the fullrace twin scroll manifold next week. This will be going on a stock motor with hks 272's and all the bolt ons.
Old Jan 21, 2008, 11:54 PM
sspaladin28's Avatar
Damn that's purrty
Old Jan 21, 2008, 11:55 PM
brokenRS's Avatar
beautiful, cant wait to see the result.
Old Jan 22, 2008, 12:08 AM
EvoRecordSetter's Avatar
please run some kind of injection or some sort of race gas or high octane mix. you require 26-30 PSI to be unstopable, but your that close, the right fuel!
Old Jan 22, 2008, 12:34 AM
tripperfx3's Avatar
Beautiful! Why didn't you just go with the full kit from Buschur? JW what the advantage of the Full Race mani. would be or if its just personal preferance.
Old Jan 22, 2008, 12:35 AM
brokenRS's Avatar
his setup is a twin scroll. full-race offer twin scroll mani
Old Jan 22, 2008, 12:45 AM
chrismnj's Avatar
sexy
Old Jan 22, 2008, 12:56 AM
i did not go with buschur because they do not have a twin scroll t3 kit. persionally i think twin scroll is where its at.
i also do not like the buschur kits because they do not use off the shelf turbos. the use a stupid mitsu flange for their turbo kits. normally off the shelf turbos are t3 or t4 flanged. so you have not free to swap turbos.
buschur also uses a custom turbine housing with a tial 44mm flange on the turbine housing. this is stupid because again you cannot swap out normall off the shelf turbos and this makes the turbo only good for the evo. i would not be able to use a buschur turbo on my honda;s or anything car, becasue buschur turbos are set up to run with only their manifold and only for evos.
+ buschur turbo kits require you to run the stock radiator. i have a thicker aluminum radiator which would not work with the buschur kits.
Old Jan 22, 2008, 01:41 AM
Jameson_IXMR's Avatar
I really like the FP twinscrolls, looking at yours baffles me, Your sticking that one in the stock position?? With a wider radiator? Looking at the hot side it seems as though the turbo would spool quicker with that middle divider ported out, but then it wouldnt be twin scroll.. Intresting, one of the rare cases where adding an obstruction increases performance. Really nice setup!!!
Old Jan 22, 2008, 02:09 AM
dxbevo9's Avatar
are you expecting this to spool faster than the normal HTA35R (non twinscroll)??
Old Jan 22, 2008, 02:50 AM
of course i would spool faster than a non twin scroll hta35r
Old Jan 22, 2008, 03:16 AM
dxbevo9's Avatar
well i should have asked this better...
how much faster than a non-twinscroll HTA35R are you expecting to spool?
Old Jan 22, 2008, 03:57 AM
sparky's Avatar
Is there a ready made DP available for your new turbo, or do you have to have one custom fabbed? This turbo will actually clear in conjunction with your thicker than stock, full width radiator? I am way jealous!
Old Jan 22, 2008, 04:20 AM
turboDan's Avatar
Yes,v-band dp's are readily available.
Old Jan 22, 2008, 05:49 AM
zbomb's Avatar
You have obviously never seen any of BR's Tubular kits. I'd suggest you take a look.
I am curious to see how this combo works. I think you will be the first person to try this setup. How quick do you think it's going to spool? Good luck
Quick Reply: finally got my FP HTA twin scroll gt3582R
